97 2.2CL Window And Lock Problems.. HELP
Old Apr 18, 2013 | 01:30 PM
Shally2186's Avatar
Angry 97 2.2CL Window And Lock Problems.. HELP
So Im Having Electrical Issues With My Car Acura CL..
Checked The Wiring And It All Seems Fine...
The Car Would Randomly Keep Trying To Lock Itself. When Driving Or Just Sitting. I Removed The Battery Out Of My Keyless Entry To Make Sure It Wasnt The Problem. After A Little While It Randomly Stopped.
Now It Doesnt Try To Lock Itself Anymore However The Passenger Door Will Not Lock When I Hit Lock On My Keyless Entry. When I Manually Hit The Lock Switch Inside The Car, BOTH Sides Lock. When I Hit Unlock ONLY The Drivers Side Unlocks.
ALSO The PAssenger Window ONLY Goes Up And Down When Using The DriverSide Switch. If You Are Putting The Window Up OR Down With The Drivers Switch, It Will Stop If You Also Hit The Passenger Switch At The Same Time.
Anyone Ever Had These Problems And Have Any Ideas On What To Pin Point?
Thanks!
Shally
MrHeeltoe
20
Feb 23, 2023 01:54 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
