97 2.2CL Window And Lock Problems.. HELP
![Angry](https://acurazine.com/forums/images/icons/icon8.gif)
So Im Having Electrical Issues With My Car Acura CL..
Checked The Wiring And It All Seems Fine...
The Car Would Randomly Keep Trying To Lock Itself. When Driving Or Just Sitting. I Removed The Battery Out Of My Keyless Entry To Make Sure It Wasnt The Problem. After A Little While It Randomly Stopped.
Now It Doesnt Try To Lock Itself Anymore However The Passenger Door Will Not Lock When I Hit Lock On My Keyless Entry. When I Manually Hit The Lock Switch Inside The Car, BOTH Sides Lock. When I Hit Unlock ONLY The Drivers Side Unlocks.
ALSO The PAssenger Window ONLY Goes Up And Down When Using The DriverSide Switch. If You Are Putting The Window Up OR Down With The Drivers Switch, It Will Stop If You Also Hit The Passenger Switch At The Same Time.
Anyone Ever Had These Problems And Have Any Ideas On What To Pin Point?
Thanks!
Shally
Thanks!
Shally
MrHeeltoe
20
02-23-2023 01:54 PM
soupi
14
11-15-2015 11:15 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
