97 2.2 losing coolant, no leak
i have a 97 2.2 cl and it has been good to me overall, recently i have noticed that i am losing coolant at a pretty rapid rate but it is not leaking outside the car anywhere, and i can't smell it burning off. it seems to lose more when running the a/c...i just got the head gasket done and the cylinder head shaved. luckily it was still under warranty from the dealer when the hg blew. it is running fine except for a minor loss of power. I thought it might be a crack in the head or block, but there is no coolant in the oil, any other suggestions?
I would suggest having a coolant system leak test performed. This should pinpoint the leak. Some places are difficult to detect; heater hose, throttle body heating hoses, water pump drain, radiator seams.
good luck
good luck
IBankMouse
Jun 13, 2020 12:53 PM
