3.0 starting problems
Old Feb 12, 2008 | 10:58 AM
blkak97's Avatar
ok i'm sorry if this has been covered before ive searched a little but really havent had time to
ok so yesturday went to start my car it clicked once didnt start so i said ok its the battery, battery is less than 2 months old, charged battery then tried to start car it just kept clicking didnt start, tried to jump battery same thing, connections are clean and tight. check ground from battery to car its good. so later during the day i turned my headlights on tried to start it to see how much they would dim and when i turned the key they dimmed alot. im at a standstill now in that id like to not have to get it towed somewheres
so umm any ideas guys?
Old Feb 12, 2008 | 12:00 PM
AznX TL's Avatar
where is....
could be your starter.
Old Feb 12, 2008 | 12:23 PM
young03's Avatar
its JDM yo!!!!!!!!
sounds like its ur starter usually clicking when u go to start ur car is a starter issue
Old Feb 12, 2008 | 04:36 PM
blkak97's Avatar
ill take it off and get it checked tom its rainin like crazy ova here
Old Feb 13, 2008 | 07:55 AM
Nakamichi's Avatar
~[ô¿ô]~
Get the battery checked for it's cranking power. Some even new batteries can be defective (hence warranty).
The copper connectors in the starter could be worn down. This happened to me. Still have to take the starter out, but if you DIY it's only a fraction of the price compared to replacing the whole starter.
Old Feb 14, 2008 | 03:33 PM
maddnotes's Avatar
I had the same problem with mine and it just turned out to be one of the connections on the starter. There is a wire with a female spade connected to the starter. Check that wire because mine was all corroded and brittle. I put a new spade on it and havn't had any problems since then.
Old Feb 15, 2008 | 06:55 PM
Mr_Xclusive808's Avatar
If the the car makes a fast clicking sound then it's definately the battery or a weak connection. But yah definately check the starter if still not the battery. Just from my experience though on the 3.0 motor putting the starter back in was a major pain because on how long that starter bolt was and looks like it threaded all the way into the block to.
Hope you get the problem fixed though.
Old Feb 17, 2008 | 02:03 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
If it's clicking it's the starter, mine went bad on my 3.0 a while back
Old Feb 18, 2008 | 02:13 AM
blkak97's Avatar
thanks guys
its been raining nonstop all week but it looks like itl slack off tom so ill try to check everything out
Old Feb 18, 2008 | 11:47 AM
Cocoa's Avatar
2600lb CL
http://autorepair.about.com/cs/troub.../aa080203b.htm
Old Feb 19, 2008 | 06:02 PM
blkak97's Avatar
ight guys thanks for all the help i finally got the ak started, it was a combination of bad starter and a corroded wire going from battery to starter
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
DNS91
Sep 29, 2015 10:11 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
