3.0 Stalling After Startup
Old May 14, 2010 | 11:11 PM
MaxMike93's Avatar
Currently Post-Acura
Currently, my '99 3.0CL has aroun 62,000 miles and only a SRI to mod the engine at all. New alternator and battery installed about a month ago. When I was by my friend's house, I parked in his driveway (a hill) and left it there for around 2 hours. When I went to leave, the engine stumbled a few times and kept dying. After 3 tries each time this happened, I kept the engine revving around 3000-4000 RPM and then it kept up. This has happened twice at that location, and then I used the remote start in my driveway (also a hill) and the car stalled. Is there some reason? The car has never been tuned-up since it is supposed to be good till 100k. Could this be some sort of fuel management in the engine? I remember once my mom's '05 Toyota Highlander would not start easily since the engine being on a tilt did not give an accurate reading of what fuel was in the cylinders to start the engine. It doesn't happen all the time, but it's pretty annoying when it does happen. Thanks!
Old May 15, 2010 | 08:04 AM
davzilla's Avatar
Your throttle plate is sticking. happens to me every once in a while.
You may want to get a tune up anyways. Or at least a check up, cause yes your car may not need service till 100k, but you usually hit that before the car is a decade old.
lol, how do you only drive 6000 miles a year? i hope it gets more than a yearly oil change.
Old May 15, 2010 | 11:43 AM
bRunCL's Avatar
didnt know our spark plugs were rated at 100K, thought that was mostly in newer cars. Anyway, my first thought when you said it gave you a problem on a hill was the fuel pump but dave has a very valid point also
Old May 15, 2010 | 11:48 AM
crx_91si's Avatar
V-DUB TECH
how much gas did you have at the time? also, was the car parked upward or downward on the hill.
i notice in my car that if i back it into my driveway (downward facing) with the tank almost on E, the car will do the same thing.
next time it happens, try rolling the car to level ground. you might have a clogged fuel strainer (on the pump), weak fuel pump (weak flow rate), or clogged fuel filter.
and that 100k tune up, that goes by time also. 7 yr. / 100,000 miles i believe.
my
mike
Old May 15, 2010 | 11:52 AM
MaxMike93's Avatar
The car was my grandmother's. It was my 17th birthday present. My grandparents mostly used thir Chevy wagon, but after that my grandmother didn't drive the car very far.
Old May 15, 2010 | 12:01 PM
crx_91si's Avatar
V-DUB TECH
and try to keep them low miles on it.
I got mine almost 4yrs ago and i've only put 20k driving about 10 miles/day
had 52k when i got it and it has 71,8xx now
for the below 100k club!
Old May 15, 2010 | 06:30 PM
on1wheel01's Avatar
I have a similar problem from time to time. Ill start it up she will sputter like crazy and then even out. I have a recent tune up and all. Only does it randomly one every few months. I figure ill just not worry about until it does it more.
Old May 15, 2010 | 07:38 PM
davzilla's Avatar
lol, i rolled over 350,000kms on the original 3.0 on friday.
Old May 16, 2010 | 12:21 AM
crx_91si's Avatar
V-DUB TECH
350,000km = 217,479.91728295 miles
not bad, not bad at all sir !
gator90065
Oct 8, 2015 10:14 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
merc009
Sep 29, 2015 03:06 PM
prbori
Sep 27, 2015 01:37 AM
rklatzkin
Sep 23, 2015 04:08 PM
