3.0 Car Trouble
3.0 Car Trouble
So I went to go eat lunch with my friend and returned to my car. I started it up and usually the RPM jumps to about 1.2 K rpm and then idles at maybe 600-800. Today it jumped up and then dropped waaaay below. Went up to 1.2K and then dropped. My tach read 0 rpm and the whole car started to shake. Puzzled, I shut the car off and tried it again. Same thing. RPM returned to around 0.
I tried to rev the engine and the RPM would go up as I pressed the throttle, but would again return to 0 when I released it.
My stereo and dash and everything still worked fine but my engine kept dying. I waited about 10 minutes and started it up again and everything worked fine.
Car was in Park the whole time this happened.
Anyone know what could be wrong? I hope it's not a tranny issue
It's a 98 3.0 with 88.6 K miles.
ok i know your new and i dont me to get on your case but use the SEARCH button...it will be your best friend. Ill help you this time..good luck
https://acurazine.com/forums/showthr...highlight=idel
The problem went away for maybe 2 weeks and it's been doing it more and more lately. This is not the same problem as the link. To clarify: the car only has this problem when i'm trying to start it up, the car fires up and then RPM drop to 0 and the car dies. The RPM will increase if I hit the throttle after it fires up, but as soon as I let go of the gas the RPM will die once more and the car will shut off. After about 3-4 tries starting it up and revving the engine I can successfully put my car in gear and drive off, but I don't know how long my car will last with this problem. Anyone?
I've been having similar problems with my car too, except it doesn't actually stall. It will start as normal, and drop to almost 0 RPMS. I have to rev it a bit and the computer kicks the RPMs back up to normal. I put some dry gas in and it hasn't done it since. Maybe something's up with the computer?
I was just going to post and ask the same thing.
Mine seems to rarely happen (started last summer). But when it does, the car has been driven and then sat for 20-30 minutes. Start it up, car dies unless I catch it and give it gas it for 30 seconds or so.
Hasn't happened for a couple months then did it yesterday. The fuel tank was below 1/4 though...
i remember it was a problem with the idle valve in our throttle body it gets all gunked up and fucks with our idle some kid took his throttle body off and cleaned it out threw it back on "problem solved"
bearingman07936
Jan 7, 2016 03:22 PM
handsom-hustla
Nov 13, 2015 05:04 PM
