2.2CL A/C smoke question...
Old Sep 21, 2005 | 03:15 PM
AceDaMan's Avatar
4th Gear
Whats goin on people? I've been a member for almost a year now, but I havent really said much. I've just been quietly reading what you guys have to say. And I can definitely say you guys know your stuff and its mad cool that you help people like you do.
I just had a question about my 972.2CL Auto. This just randomly started about 2 months ago. When I turn the A/C on eventually(usually like 5 minutes later) some smoke begins to pour into my car. And there is a lot that drifts out of the vents, It usually doesnt stop for about 10 to 15 min and then eventually comes back again. I've been told that it could be humidity or it could be coolant/freeon. I put a napkin up to the vent for a couple of minutes and there was no color or smell.
Has anyone heard of something like this before? I've got 105,000 miles if thats pertinent to the situation.
Old Sep 21, 2005 | 03:26 PM
hybridnrg's Avatar
...is now Carbon Fiber'd
what color is the smoke? i had this happen to me once, but it was one of my wires that fried, and i just got my windows tinted so i had to pull over with the quickness and get out. do you have it on recycle or letting the air in? I would really get this checked out. no smoke should be going into the cabin
Old Sep 21, 2005 | 03:33 PM
agranado's Avatar
how handsome I am
when you said smoke I thought "o'snap he's got a fire in his vents" If its just a clear haze maybe its condensation...(?) Cold A/C vs humid cabin = your problem perhaps?
Old Sep 21, 2005 | 06:19 PM
Sdog2012's Avatar
We dont love these hoes
This happened to me for the first time last night, it was pretty humid out but i've driven in much more humid weather before.. i just shut the air off and turned it back on and it was fine
Old Sep 22, 2005 | 12:09 AM
AceDaMan's Avatar
4th Gear
Yeah, I did the same thing the first time it happened...Shut the air off and it was fine, but when I turned it back on later it still happened. A lot of people I know are saying condensation...but its weird how it happened in the middle of the summer when its been humid the whole time. Im just hoping something big isnt going, because Im still making loan payments on the car.
Old Sep 22, 2005 | 05:39 AM
saiko_cl_duck's Avatar
condesation will do it, and it happens sometimes to me ( North Cakalackee=HUMID), but it shouldnt happen often.....have you had your A/C serviced lately? when mine was doing it all the time, i recharged my A/C, and good to go, hardly ever does it. good luck
Old Sep 22, 2005 | 08:26 AM
AceDaMan's Avatar
4th Gear
I havent had it recharged...but Im about to take my car in for pre-winter service. Any other recommendations on what I should do to it or have them look at? How much a does an a/c recharge for the 2.2CL cost? And is that just a freeon flush? BTW, I appreciate all your help.
Old Sep 28, 2005 | 02:51 AM
RECHARGE IT, IMO, that should do the trick, like i said, worked for me. If not, it shouldnt cost more than 65-75 bucks for a flush ( but dont quote me on that!)...but like any flush, make sure nothing gets busted ( line hoses, etc ), that could cause some real problems for you later. Check your lines from the condenser out and look for leaks, cracks, or loose connections on it.
Old Sep 29, 2005 | 06:39 PM
iz slick's Avatar
same thing happened to me when i frist got it.. 90 degrees out side.. i had the AC running for 20 mins parked.. i took it of n left the fan on i saw the light mist type smoke.. i got scared den i realized the fan was spittin out warmer air.. and goin thru the duct which was prob ice cold.. ;]
Old Jun 9, 2009 | 08:26 PM
whittles's Avatar
I have this problem on my 99 2.3 cl. I get smoke mist whenever the ac is on but If I put the ac on 60 and on high speed it helps the problem. It also seems like there maybe a vacuum leak or something like that behind the glove box , blower is on. Any advice?
Old Jun 12, 2009 | 06:33 PM
TexasHonda's Avatar
"Smoke" is usually condensed water vapor coming off a completely iced evaporator. Why? Compressor is not cycling, but continually running and cooling evaporator to sub-freezing temps. There is a thermosensor that should be plugged into evaporator. When temp reaches about 28F, the compressor is cycled off and remains off until temp reaches about 45F, then compressor re-engages. If your compressor is not cycling on/off, this is the cause of "smoke".
good luck
Old Jun 14, 2009 | 12:48 AM
South Jersey CL's Avatar
i was in traffic once, with the AC on letting in air, and a mustang in front of me did a burnout and all that smoke went straight through my vents. and to answer your questions, its probably vapor, not smoke.
Biggie_B
May 27, 2025 05:51 PM
hashbrown
Sep 29, 2015 12:13 PM
jmaxima03
Sep 27, 2015 10:22 AM
prbori
Sep 27, 2015 01:37 AM
