Spring/shock install
Old Jul 26, 2009 | 04:21 PM
  #41
WineRed2.2CL's Avatar
Old School Ridin Clean
did you try to jack trick? jack that part up a bit with a separate jack
Old Jul 31, 2009 | 07:07 AM
  #42
Master Bill Flex's Avatar
Took it to the mechanic, he had to drill out the bolts and replace the assembly. The bill came out to be 160 bucks to replace the back shocks
Old Jul 31, 2009 | 08:25 AM
  #43
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
not too bad i guess
Old Aug 23, 2009 | 11:51 PM
  #44
Project_CLean's Avatar
MMkay.
i redid my suspension..4 days ago
thers something they sell at an autoparts store..called pb blaster..its up to u if u wanna try it ..i sprayed my bolts twice a day..for 3 days before i went to try it..came out with a little force.. same for the front..make sure u take ur time with the pinch bolt on the front fork..i had to "fork" out 110 bux from the dealership because i broke the head off the bolt ..didnt even get it a little out so there wuz no chance in drilling it out..i would recommend changing the pinch bolts for the front...depending on what kind of struts u got.i got minez from autozone..thers a tool u mite need to hold the rod from spinning when you're tightening the bolt that holds on the mount to the assembly..i used vices but stripped the hell out of the rod..
http://www.polaristools.com/online-t...product_id=115
==orr==
http://www.autopart.com/tools/help/c...s/steering.pdf
part no. a450
Old Sep 27, 2009 | 11:56 AM
  #45
Bmcneal11's Avatar
I followed these steps and more but i had a problem and couldnt finish the spring instillation.
When I got the srut and old spings out i coulnt even budge the 1 bolt that was holding it all togther.
Is it just really tight or do i need a special tool or something?
help would be grately appreciated
thank you
Old Sep 27, 2009 | 02:11 PM
  #46
(Mid-Atlantic)
It's probably just rusted, spray some penetrating lube on it, and make sure it's secure before breaking the nut loose
Old Sep 27, 2009 | 10:09 PM
  #47
Bmcneal11's Avatar
ok thanks
im gunna give it another try in the next few days
Old Sep 30, 2009 | 02:24 PM
  #48
apetastic's Avatar
the last time I was messing around with my cars springs, I didn't have a spring compressor. We used 2 ratcheting straps one on each side. granted, I wasn't lowering I was lifting so the springs were huge. I honestly thought I might die. I don't recommend it at all haha.
my main problem has been trying to get the lug nuts off of the back wheels. the damn thing won't come off. I've sprayed it with everything I can think of, I've tried using the weight of the car and a tierod. The thing is rounded off even for the next size down. Does anyone know where I can buy a breaking bolt to get that off? I know that like les schwab or the like have something like it that they hammer on to break it loose but can you buy that somewhere? I don't want to pay $5 bucks a lugnut when I have to do both back wheels.. plus its becoming a theme with most of my vehicles. Must be where I live or something
Old Apr 15, 2010 | 10:48 PM
  #49
salogCL's Avatar
does anyone have the specs of these bolts?
Old Apr 29, 2010 | 10:23 PM
  #50
salogCL's Avatar
so im going to be tackling this on the weekend.
been spraying the bolts down with PB for a few nights.
wish me luck. if i come up with any intresting ways to help get things out smoothly i will add them
Old May 2, 2010 | 06:24 PM
  #51
salogCL's Avatar
Alright so i did the swap ( agx's + neuspeed springs). took me a day and a half.
startedon rears, snapped the bolt head off ( after spraying with PB for a few nights) witht he breaker bar. cut out the shock. melted the rubber with a torch. the cut the bushing with a sawzall.
next problem.. how do i get the new bushing in. i bought it before in case this happened. no way it was fitting without a press. no way i was taking anything out and to the shop.
so i started dremeling the bushing until t just barely fit. torched the control arm and hammered it in.
other side i did like an hour and half lol
did the fronts the nex day. easy stuff, took maybe 3-4 hrs.
tips: buy extra parts before you start. air tools are useless, unless you have something that fits tight spaces. use caution with breaker bar. if those lower bolts arent coming out and you dont have the knowhow or tools stop there , take it to the shop. the rears are tricky to put in, get a partner to help. the front pinch bolts are easier to undo with the shock in the car and the fork still bolted in.
Gluck to all ... it can be a tough job but with the right tools... easy pie, and results are well worth it
Old May 6, 2010 | 10:10 AM
  #52
Iagent's Avatar
Take a look at my Avatar. That is the back lower bolt cut for removal. Then I had to borrow a press to get the bushings out. That's the way it is in the Midwest rust belt.
Old May 6, 2010 | 04:56 PM
  #53
salogCL's Avatar
lol you mean this nonsense
Old May 7, 2010 | 09:18 PM
  #54
Iagent's Avatar
Yep! Looks very familiar. I did mine three years ago, and now I need to go back into the fronts to replace the springs. Both front Eibach springs broke. Eibach just sent me two replacements free of charge, but I hate doing the spring compressor routine. Just glad it wasn't the back ones!
Old May 7, 2010 | 09:46 PM
  #55
Iagent's Avatar
BTW, here is my little pile of debris.
But it was worth it!
Old May 7, 2010 | 10:11 PM
  #56
switchfootvz's Avatar
Rockin the D2! Purple Pwr
what broke?
Old May 8, 2010 | 12:54 PM
  #57
salogCL's Avatar
lol 2 bushings.. sucky man. but agreed worth the work
Old May 8, 2010 | 10:27 PM
  #58
Iagent's Avatar
Beautiful Silver CL!
Old May 9, 2010 | 02:31 PM
  #59
Eband27's Avatar
Hahaha, Damn bushings. On my left side, everything was like butter, no problem...
Right now the car is still sitting on jack stands.. because the rear lower bolt got seized in the bushing and turned on itself, ripping the bushing and actually pushing that tab with the welded nut outwards... It was too late when i realized what i was doing. Now im trying to cut the bolt off, to take the thing out. And find a way to put in the new bushing, SOB
Old May 9, 2010 | 04:56 PM
  #60
salogCL's Avatar
getting the bushing in can be a nightmare, its meant to be put in with a press and the hole heated up big time with a torch. i ground mine down lil by little with a dremel and fine sand paper wheel. until it just barely fit .. then hammered it in.
i am actually considereing filling around the sleeve with some solder / lead to ensure a tight fit
Old Feb 12, 2011 | 06:03 PM
  #61
timeizmoney22's Avatar
Took my rear struts out today. ?????? Do you have to compress the spring to get it off the rears, or are they not that compressed? Am considering bringing it to a shop and having the swap the springs and bushings over to the new strut.
Old Feb 25, 2011 | 02:26 PM
  #62
[quote=timeizmoney22;12704718]Took my rear struts out today. ?????? Do you have to compress the spring to get it off the rears, or are they not that compressed? Am considering bringing it to a shop and having the swap the springs and bushings over to the new strut.[/quot
Finished!
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
