Request: how to change ABS wheel speed sensor?
Old Oct 13, 2006 | 02:26 PM
christopher g's Avatar
as above
Old Oct 18, 2006 | 06:40 AM
Mach30SiR's Avatar
Bagel Bomber
Sorry i cant help you out chris - you'll find more people talking about carbon fiber hoods than anything else on here - you'll have to sort through the information to find anything worth reading.
I could be very wrong but aren't the sensors on the axles?
Old Mar 4, 2008 | 11:13 PM
Grn97cl's Avatar
V-Dub This
still need to know 2 years later?
Old Mar 13, 2008 | 11:33 AM
TMO's Avatar
TMO
I actually have trouble with my ABS. Do you have a DIY?
Old Mar 24, 2008 | 11:32 AM
Grn97cl's Avatar
V-Dub This
i can get you one for the speed sensor
Old Mar 25, 2008 | 06:45 AM
TMO's Avatar
TMO
that's exactly what I need!!
Old Apr 1, 2008 | 03:24 PM
jham65's Avatar
Add me to the list of needing this information!
Old Apr 1, 2008 | 03:51 PM
99 CL's Avatar
3rd Gear
ABS Info
Add me to the list also!. I have an intermittent issue with ABS light coming on..going off.. Maybe it is a bad sensor or possibly excessive brake dust being accumulated on the sensor itself. Haven't really looked into it much as I need more info on the sensor assembly. BTW, I have Brembo sport pads which create more dust than previous stock pads.. IMO
Old Aug 27, 2008 | 03:06 PM
Blind_Shooter's Avatar
For Life
^^anyone with a DIY, to help people out??
Old Aug 27, 2008 | 09:07 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Is there any other way to test for a bad wss or do you have to pull the code to find out?
Old Aug 29, 2008 | 05:00 PM
For Life
im gonna try spinning the individual wheels. im pretty sure mine is the back right because it looks like it was put on backwards. dont ask why i didnt do it i just saw it looking weird. but long story short i still wanna know how to do it if anyone wants to help
Old Sep 22, 2008 | 06:41 PM
vintage_steeps's Avatar
5th Gear
The biggest most important thing that you need to know is which wheel sensor is bad. I just bought my CL and i have not looked it over . However each wheel should have a sensor. If the fr r is bad doesnt make sence to change the other side... Now you need a mechanic or someone to scan the car and tell you which sensor is bad. (They should charge you no more then 45.00 for the scan) The sensor should be the only thing attached to your wheel near or on your brake caliper with a wire. Just unplug the wire and replace the old sensor its very common sense once you pull the wheel and see the wire.
Old Sep 22, 2008 | 07:25 PM
For Life
almost positive its my right rear as it looks like someone used a different wheel speed sensor than what should have been there (mounts dont line up, like its a rear left wheel speed sensor)
Old Nov 6, 2008 | 09:27 PM
TrueNorth's Avatar
'97 2.2CL 5spd
Is there a difference between the wheel speed sensors for each wheel? I thought they were all the same. Will a wheel speed sensor work for any of the fourn wheels?
Thanks,
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
lland
Oct 4, 2015 04:47 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
