Need help with timing belt replacement
Old May 12, 2010 | 01:40 PM
Acura Sensei's Avatar
all stocker
Can anyone help with a laundry list of parts needed for the timing belt replacement? I have a '98 2.3cl with 114k miles.
I searched and didn't find too much info. Any help is appreciated.
I found some kits on rockauto.com, but not sure which kits are needed.
How much can I expect a shop to charge to replace the belts, plugs and water pump?
Thanks, can barely think with a newborn in the house. Lol.
Should I go into a shop with my own parts? Any other suggestions would be welcomed.
Old May 13, 2010 | 10:37 PM
all stocker
24 views and no replies?
Can anyone help to confirm all parts needed?
Old May 15, 2010 | 02:52 AM
tron's Avatar
You should replace the following when doing the timing belt:
Timing belt
Balance belt
valve cover gasket
cam seal
crank seal
water pump
alternator and ac belt
power steering belt
If your bringing it to a shop, I would let them buy the parts. If you decide to bring your own parts, make sure they will warranty the work.
Old May 15, 2010 | 10:53 AM
Iagent's Avatar
Around here in the Chicago area, they like to charge about $500-800 for the 4cyl. I've always replaced my own timing belts. Call around a bit and see what their price is.
merc009
Sep 14, 2015 06:43 PM
iCrap
Sep 11, 2015 06:21 PM
Phambam12
Sep 5, 2015 04:10 PM
asahrts
Sep 4, 2015 05:55 PM
