Glove box removal
There are 2 screws holding in the glove box at the bottom, simply remove those 2 screws, undo the handle, you will also need to remove the 2 rubber stoppers, one on the left is a clip, the one on the right needs a quarter turn with a flat head screw driver. You also will want to carefully remove the shock absorber, because the clip is really fragile. cheers
I found a much easier way to do this. I removed the two screws with washers from the bottom of the glovebox they were holding the hinges on and then i just unscrewed the piston from the side.
SidhuSaaB
May 30, 2020 12:40 AM
STL TL-S
Sep 23, 2015 08:52 PM
