engine help mine is dead
hello first off i have a 1998 cl 2.3 5-speed! my f23a1 is dead! i need another motor (swap) or rebuild my old one but i dont have much money and i dont like headaches is there a motor that is easy to put in, and cheap, and be more powerful than the f23 i have been thinking about the f20b and the h22 but thats really all i know i need yalls help the easier and cheaper the better but keep in mind i would like to have more power!!! and also i would need parts lists for each swap. thanks in advance!!!
will this fit and also what all would i need
K24A4
K24A4
- Found in:
- 2003-2005 Honda Accord, 2003-2006 Honda Element
- Displacement: 2,354 cc (143.6 cu in)
- Bore and Stroke: 87 mm x 99 mm (3.43 x 3.90 inches)
- Compression: 9.7:1
- Power: 160 hp (119 kW) @ 5500 rpm (166 hp in 2007/2008)
- Torque: 161 ft·lbf (218 N·m) @ 4500 rpm (@4000 rpmin 2007/2008)
- Redline: 6800 rpm
There is a mount kit for the k24 but it would require a lot of work, the h22 uses the stock motor mounts and drops right in, search around for h22* or swap because several members have them in their CL's
i found where Palayh8ta did the swap for the h22 but seems he had some troble but i guess anything like this will have a few bugs to work out. would like to talk to him but i cant figure out how to pm him. and also i want to keep my f23 5speed so what clutch and flywheel would i use??
How cheap is cheap? A replacement F23 is probably something like $500. An H22 from a used engine reseller is about $2k plus a few hundred for shipping. I like the K24 idea, but I don't know what those go for.
If you aren't doing the swap yourself, you'll need another $500 for labor. While you're doing the swap it always good to replace the belts, water pump and maybe even the oil pump.
Sep 17, 2015 09:01 PM
adreano17
Sep 16, 2015 02:54 PM
