change front marker lights
how do you change the front marker lights? i was goingto get the ebay smoked ones. also how many bolts hold the headlight in? i notivced two on the top and one on the inner side by the radiator.
It's all here, just search man, also check out the diy/faq forum, that's where a lot of this info can be found
Corner install
https://acurazine.com/forums/1g-cl-diy-faq-74/clear-corner-install-470705/
Headlight removal
https://acurazine.com/forums/1g-cl-diy-faq-74/black-housing-headlights-w-front-bumper-removal-470662/
To remove the headlights you have to remove the bumper, I believe it's 6bolts per headlight, it may be 5, don't remember
Corner install
Headlight removal
mada51589
Jan 9, 2025 04:40 PM
