xtant or kicker
Old 12-31-2003, 08:52 PM
Miss th 3.0
wakeboardfusion's Avatar
xtant or kicker
i am going to get 2 jl 12w3v2's and which amp should i get
the xtant
http://cgi.ebay.com/ws/eBayISAPI.dll...category=18797
or the kicker
Old 12-31-2003, 09:03 PM
Trailblazer = SUCK
LCARUCA 97's Avatar
Xtant all the way man.
Old 12-31-2003, 09:16 PM
The movement has started
baka_t's Avatar
My 1st choice would be rockford but if you care about your system sounding more musically the xtant is the way to go. Very clean sounding and lots of power. Also they draw less power then rockfords. Which is good.
Old 01-01-2004, 01:38 PM
Miss th 3.0
or what is another amp i should consider?
Old 01-01-2004, 02:12 PM
1999 CL3.0
dragon084's Avatar
xtant / JL Audio / MMATTS / <- those are tops
Premier / Rockford / Pheonix Audio <- all good as well
try to stray from kicker, mtx,
you know, stuff that's sold at chain stores. then again some
chains specialize in good stuff only
but u know you get what u pay 4, go with XTANT
Old 01-01-2004, 02:15 PM
1999 CL3.0
dragon084's Avatar
http://www.acura-cl.com/forums/showt...threadid=70795
Old 01-01-2004, 02:22 PM
Miss th 3.0
should i go with
or
Old 01-01-2004, 02:40 PM
1999 CL3.0
dragon084's Avatar
cant lose with either
depends on if you want the titanium look
i say you get the one thats cheaper unless ur building a show
system
Old 01-01-2004, 04:28 PM
baka_t's Avatar
It really all depends what you want. If you want to have a really loud system id go with a rockford amp. The downside is they will draw more power then the xtant which mite require a cap. The rockford is a little cheaper then the xtant http://cgi.ebay.com/ws/eBayISAPI.dll...ayphotohosting but will be louder IMO. Ive herd a system with an xtant setup and rockford setup with jl's and the subs with the rockford amp was louder but the xtant was cleaner. All depends what your looking for. Just thought id give you another idea before you make your decision.
Old 01-01-2004, 04:39 PM
Miss th 3.0
that amp wont wont work with the 2 jl dual 4 ohm subs
Old 01-01-2004, 05:43 PM
Trailblazer = SUCK
LCARUCA 97's Avatar
Piss on both of those and get these!
Old 01-01-2004, 09:24 PM
baka_t's Avatar
Well if you read the user manual you should know that the subs can be run in series or parallel. The subs would work in series with that amp which is actually a safer way to run subs with an amp. Using a lower impedance will put more stress on the amps internals and more strain on the electrical system. Running an amp in that state will certainly shorten the life of the amp and cause heat issues.
Old 01-01-2004, 09:28 PM
baka_t's Avatar
Sound stream amps are nice amps but hardly last. I think i been through 10 already and that was running 4ohm non bridged. Sure they sound great but why buy a used amp?? Who knows what its been through and how much life is still has left.
Old 01-01-2004, 09:29 PM
Miss th 3.0
so what would be the perfect amp for those subs?
Old 01-01-2004, 09:37 PM
Miss th 3.0
would this be a good option, or should i stick with class D
http://www.crutchfield.com/cgi-bin/S...=0&cc=01&avf=N
Old 01-01-2004, 09:40 PM
Miss th 3.0
should i go with that xtant d class or that RF 2 ch
Old 01-01-2004, 09:43 PM
baka_t's Avatar
If you want to get crazy get a 801s http://cgi.ebay.com/ws/eBayISAPI.dll...category=39737
If your running more then one amp you would have to get a cap. If you buy a rockford get it off ebay there way cheaper.
Old 01-01-2004, 09:44 PM
baka_t's Avatar
Class d's are fine but will never match the power the rockford has.
Old 01-01-2004, 09:45 PM
Miss th 3.0
yea...i would get it off e bay, but could you tell me what the best posible amp to buy for these subs
Old 01-01-2004, 09:50 PM
baka_t's Avatar
If you want it to slam buy a rockford if you listen to classical buy a xtant.
Old 01-01-2004, 10:06 PM
Miss th 3.0
baka_t do u have aim or msn?
Old 01-01-2004, 10:18 PM
got audio?
97Black2.2CL's Avatar
you are running 2 subs correct? how amps are you planning on buying?
Old 01-01-2004, 10:21 PM
Miss th 3.0
they r rated at 300 rms and that is what i am planing on puttin into them
Miss th 3.0
so i need 600 rms for both
Old 01-01-2004, 10:22 PM
Trailblazer = SUCK
LCARUCA 97's Avatar
sorry man but rockford is cheap mass produced garbage. It used to be decent stuff about a decade ago. And here is a clue, they sell it at best buy, that should be enough basis right there. Unfortunately not a lot of people make good shit anymore. I wouldnt buy any soundstream stuff except the reference series stuff which all of it is about 10 years old at least. I bought my amps used and they perform like no other. definately money well spent. btw cheap amps (rockford) probly will die prematurely under heavy loads. They are designed cheaply and have weak power supplies in them. I had my ss bridged down to 1/2 ohm for just over two years before i changed my setup and never had one problem at all.
Old 01-01-2004, 10:26 PM
Macleod52's Avatar
^^^ I can vouch for that. The man know's his audio!!!!
Miss th 3.0
i am going to buy a new amp, what is one i should buy then?
Old 01-01-2004, 10:27 PM
Trailblazer = SUCK
LCARUCA 97's Avatar
go with a PPI or an xtant.
Old 01-01-2004, 10:39 PM
Miss th 3.0
i am leaning towards this xtant
http://cgi.ebay.com/ws/eBayISAPI.dl...&category=18797
because if i got this PPI each sub will be 100 watts rms over
http://cgi.ebay.com/ws/eBayISAPI.dll...category=18796
Old 01-01-2004, 10:44 PM
Trailblazer = SUCK
LCARUCA 97's Avatar
Dude thats totally ok. The more power the better. Just learn to use it wisely. My sub amp has waayyyyyy more power than Ill ever use. But it has great dynamics when i need it.
Old 01-01-2004, 10:49 PM
Miss th 3.0
would there be a big difference between those 2 amps? like one is class d and the other being a 2 ch
Old 01-01-2004, 10:51 PM
Trailblazer = SUCK
LCARUCA 97's Avatar
i cant see the xtant link
Old 01-01-2004, 10:56 PM
Miss th 3.0
Old 01-01-2004, 10:59 PM
Trailblazer = SUCK
LCARUCA 97's Avatar
i put that same exact amp in my buddies 92 caddy big body pushing two alpine R subs. It has gobs of power and thats a huge ass car. So imagine what it would sound like in the cl.
Old 01-01-2004, 11:01 PM
Miss th 3.0
mmmm...sounds tastey...im gunna get it...should i get those jl audio subs or should i look for something else?
Old 01-01-2004, 11:02 PM
Trailblazer = SUCK
LCARUCA 97's Avatar
id go with JL's. They are nice. what other options do you have?
Miss th 3.0
just tryin to keep the sub cost under 300
Old 01-01-2004, 11:04 PM
Miss th 3.0
lcacura97, do you have aim or msn or yahoo?
Old 01-01-2004, 11:06 PM
Trailblazer = SUCK
LCARUCA 97's Avatar
xanadu998 = aol
Old 01-01-2004, 11:23 PM
1999 CL3.0
dragon084's Avatar
JL subs all the way
Quick Reply: xtant or kicker
