WTB: Gauge Cluster
The odometer is part of the speedometer, so to swap it you'd have to swap the whole gauge. As for auto to manual, they are the same cluster, the auto just has the indicators in the middle. So swap the manual trim from your old cluster to the new one. You can also swap the PC board on the rear of the cluster, which will swap the actual lights for the gear indicators over as well.
On top of all this, an Accord cluster will work as well, but you need to swap the individual gauges from the accord housing to the CL housing as the mount points are different.
The 3.0 and 2.2/2.3 Tachs are also different, but the small PC board attached to the tachs can be swapped for interchanging.
what do u think would be easier, getting cluster from a 3.0 CL, or Manual Accord?
Well, the accord gauges have a slightly different font and needles, for some its more attractive, some its not. Each gauge is held into the housing with 3 or 4 screws which are also the conductors, linking each gauge to the rear PC board. Accord clusters are much easier to find, but like I said, you'll need to swap the individual gauges over to the CL housing. Also, manual accord clusters tend to sell for quite a bit more than the auto clusters.
What exactly are you going for? a new look? or are some of your gages broken?
Originally Posted by hybridnrg
knowing him...he broke it.
That he did, tryin to install his new gauge faces. SOunds like kumar got your back though, good luck daniel.
I broke the board where the lil 5mm bulbs go in to illuminate the gauges from the top. I am removing the board and replacing the 5mm with 39mm-42mm dome light leds. Starting project tomorrow. Should be done tomorrow or the day after. It should come out looking nice.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
brandnewcolony
Sep 12, 2015 10:39 AM
