Wiring Autometer Gauges..
Old Mar 12, 2002 | 08:44 PM
niedejb's Avatar
Swaps? $3000 for 50HP? :(
Anyone wired these to the factory dimmer. My first attempt has them dimming when the dash lights get brighter and vice versa.
Guess I need to drink after working on the car and not during.
I used the middle of the three wires going to the dimmer. Dont use this one. Any ideas?
Old Mar 12, 2002 | 08:53 PM
haiduc's Avatar
Moderator Alumnus
yeah......use those. keep the same ground, but switch the power.. try that. lemme know.
and have another beer.
Old Mar 12, 2002 | 09:03 PM
niedejb's Avatar
The wire I used varied from 8V to .22V while turning the knob. I thought itd be the right one....apparently not.
Do you know which of the other two I need.
I know every one of you have the reverse xenon dayglo hyper neon indigo girls gauges, which wires did you use for the 12V+.
Old Mar 12, 2002 | 09:28 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Hmmmmmm........
After that comment; just might let you figure it out on your own! :P
Have fun!
Old Mar 12, 2002 | 09:34 PM
RidinLow's Avatar
Scooby Guru
Do you have a voltmeter? I've encountered the same problem & you just need to use a different combination of wires... sorry I'm not being more helpful, but that's all I can remember at this point.
Old Mar 12, 2002 | 10:15 PM
clac225's Avatar
tlac356
I know every one of you have the reverse xenon dayglo hyper neon indigo girls gauges, which wires did you use for the 12V+. [/B]
your one to talk, Mr. Generic
Old Mar 13, 2002 | 06:40 AM
niedejb's Avatar
Please explain
Old Mar 13, 2002 | 10:06 AM
NOMAD's Avatar
Midnight Marauder
Connect the power wire to the Red with Black lines wire and the ground to the Black wire.
I did the same thing as you the first time I wired my indiglows because I figured I'd go with solid red and solid black to wire it to.
Switch the red and you'll be fine
Old Mar 13, 2002 | 04:42 PM
JLai's Avatar
Cause stock sux.
Is it ok to not power it up through the dimmer switch? My indiglos already use that and they be fuxed as it is.
Can I just power the light and power connection and not worry about being able to change the light intensity?
BTW...anyone put in a water temp guage before? The Air/Fuel looks pretty easy, but the water temp guage has this metal sensor part you're supposed to install. Is it gonna be a real pain in the ass and I should just let someone do it for me?
Old Mar 13, 2002 | 05:12 PM
dcsquirm88's Avatar
I installed the water temp in my car. Its not that hard the way I did it. The only catch is the stock water temp on the car will not work. If you want intructions to do it that way let me know and I'll post them.
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
