Windshield crack
Old May 31, 2005 | 12:05 PM
BDiddy's Avatar
Windshield crack
Well, I was driving to work this morning and a semi that was in front of me kicked up a huge rock that hit my windshield. You guessed it, my windshield now has a 1/2" chip in it. So, I called my insurance company to see how much it would be to fix, but it's not worth it to claim, since my deductible is so high. So I proceeded to AutoZone where I found a Windshield fix-a-dent kit, which I will try out tonight. I'm going to try it out tonight...screw it, if it doesn't work, then I'll need to get a new windshield anyway...no loss. Has anyone used one of these before--if so, does it work well?
Old May 31, 2005 | 12:47 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Good luck, it'll be an interesting project. As long as it doesn't spider out, or crack more, you should be ok. when u say 1/2" chip, do you mean long or deep? just curious, good luck diddy
Old May 31, 2005 | 01:17 PM
BDiddy's Avatar
The actual chip mark is about 1/4" in diameter but the small cracks in the glass make it about 1/2". Yeah, I think you're right--as long as it doesn't spider out it shouldn't be too bad to fix, which is why I'm trying to fix it ASAP. Thanks.
Old May 31, 2005 | 01:20 PM
ajtcl's Avatar
Peace, Love & Acura
if the spider legs start to grow, you can take a glass cutter and curley-cue the crack so that it will crack into itself and stop growing. Hope the chip fix works for you.
Old May 31, 2005 | 03:32 PM
2point2CL's Avatar
actually last weekend i just used that "fix a chip" stuff. Used it on 3 cracks its really easy to do, you just have to make sure that you try and get lots of resin in the cracks so it doesn't spider web anymore. Also use a lighter on the inside of the glass while you let the resin sit. This helps the resin get in all the cracks and harden faster. Lay a towel on top of your dash while you do it to so you dont burn anything too nice lol. Hope that helps somewhat.
blaine
Old May 31, 2005 | 04:30 PM
EPS CL's Avatar
SSM Accord V6 6 Spd
sorry to threadjack, but what about the windshield just getting pitted and worn from age? is there any compound that will clean up the surface of the glass and even it out some?
Old May 31, 2005 | 05:03 PM
acleco's Avatar
aren't there places where they can just fill in the crack. it'll be about $50. they have that up here in some parking lots.
Old May 31, 2005 | 05:27 PM
wjk's Avatar
wjk
That's my problem... I heard toothpaste is the cheapest way to go, but there is a $40.00 paste you can get in an autosupply store. I imagine its a very fine grain buffing agent...
TheMuffinMan
Jun 2, 2022 07:11 AM
bluetl04
Aug 16, 2016 02:49 PM
jsonkimz
Mar 28, 2016 07:49 PM
rhdune16
Sep 28, 2015 11:31 AM
ceb
ILX
Sep 27, 2015 10:56 AM
