Window will not go up or down....??
Old Mar 24, 2006 | 02:33 PM
wilsonjg's Avatar
1999CL2.3.........closed door..........heard an "odd sound".........window will not go up or down. I've "manually" pulled it up so that it is shut, but it still have free travel.
If I use the switch on the door, I can hear the motor running inside the door and there is a little "grinding" at the end of each up or down stroke.
Please tell me I just knocked the window off of the lift bar?? ?? ??
How easy will it be for me to get inside my door without completely screwing up the factory seal of the door? Any special tools or replacement clips needed to return the door to original state?
Not as good of a repairman as most of you guys, so be kind!
thanks!
Old Mar 24, 2006 | 02:35 PM
teh CL's Avatar
its your window regulator motor..sloo97CL answered it in ur other thread
ebay > *
ShavedH22CL's Avatar
fear and Loathing
Its easy just make sure you take off the molding around the handle and lock. and there will be a little clip/plug for the electric just dont rip it off you should be straight. few screws. just push up and off
Old Mar 24, 2006 | 03:49 PM
Sfinlen's Avatar
Roll Tide!
http://home.comcast.net/~bobobutler/...ra_Window.html
it's definitely your regulator I just had that same problem about 3 weeks ago and found this site when I searched. Made it alot easier than I expected. Hope this helps!
Old Mar 24, 2006 | 04:10 PM
ib_jimmy's Avatar
good job pictures and everything.
Old Mar 24, 2006 | 04:43 PM
hybridnrg's Avatar
...is now Carbon Fiber'd
yeah its your regulator for sure...i had the same thing. Its pretty easy to install....once you figure it out.
Old Mar 24, 2006 | 07:44 PM
SupraManAG's Avatar
One custom CL
check your fuse
wow i can diagnose probs when drunk
Old Mar 25, 2006 | 03:07 AM
shineynitelite's Avatar
NAWWWWSSSSSS
wilson, i hate to break it to you man....
when your window doesnt go up or down, its broken
Old Mar 25, 2006 | 03:20 AM
ajtcl's Avatar
Peace, Love & Acura
Regulator cable end severed. Certainly not the fuse if he hears it grinding in the door. Good luck bro.
Old Mar 25, 2006 | 07:24 AM
SupraManAG's Avatar
One custom CL
lol
yeah it doesnt sound like the fuse
i did and said some odd things last night
drank too much
Old Mar 25, 2006 | 08:58 AM
NAWWWWSSSSSS
^^ you idiots still cant figure out whats wrong with it? i told you its broken
Old Mar 25, 2006 | 10:39 AM
SupraManAG's Avatar
One custom CL
^^you Think??
Old Mar 27, 2006 | 01:03 AM
saiko_cl_duck's Avatar
^^no, this only happens once a week here.
Old Jun 12, 2006 | 11:52 AM
wilsonjg's Avatar
FINALLY ordered a new one and fixed it Saturday...........
5 minutes to get the door panel off...
10 minutes to remover old dead motor...
5 minutes to install new motor...
3 FRIGGIN HOURS TO REPLACE DOOR PANEL!! !! !! !! !! !! !! !! !! !! !! !! !!
Old Jun 12, 2006 | 01:37 PM
hybridnrg's Avatar
haha yeah putting the door panel back on was a bitchz
Old Jun 12, 2006 | 05:44 PM
NAWWWWSSSSSS
that sucks lol
Old Jun 12, 2006 | 05:49 PM
SupraManAG's Avatar
One custom CL
iv done it so many times it takes me 5 minutes
Old Jun 12, 2006 | 08:22 PM
Racer510dude's Avatar
LOL...yes it can be a bitch if you do not know the trick.
Old Jun 12, 2006 | 09:12 PM
asianspec's Avatar
the hard work paid off!
Old Jun 12, 2006 | 11:37 PM
NitiNiteZ's Avatar
The Hefty 2.2
priceless...
Old Jun 14, 2006 | 10:23 PM
wilsonjg's Avatar
TRICK ! ? ! ?
NOW YOU GUYS TELL ME THERE'S A TRICK!! !! !!
Old Jun 14, 2006 | 10:50 PM
SupraManAG's Avatar
One custom CL
by door panel
Old Jun 15, 2006 | 02:21 AM
cvschoolboy209's Avatar
i actually just ran into the same problem..... and for me the problem was the wire part of it ripped and it clogged the passage way. what i did was order the reuglator and motor which comes as a whole for 75 bucks and changed it. if you dont know how to change it like i did it might take a while till you figure it out...... took me about an hour and a half.
Old Jun 15, 2006 | 09:27 AM
wilsonjg's Avatar
^ Ya got that right!! It whipped my butt for sure!! !!
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
AcuraKidd
Sep 25, 2015 11:18 PM
