When it comes to better handling, does a 1.5 finger gap differ from no gap at all?
I'm going to be installed F&R sways and getting the suspension tuned altogether (corner balancing etc).. i was just considering this cause the lower, the nicer it looks, but i dont want to sacrifice performance. if it helps, then great! if not.. ill leave it. if its insignificant, imma be dropping it
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by 2point2CL
its cool man, its all love on the cl-zine
:gheyhug:
Generally the lower the better, but if you get too low it'll rub and bottom out on occasion. One of those delicate balance things you just have to play with until its right.
Originally Posted by SilverCL97
no such thing
Although "visually" you are correct you can never be too low.
I'm a llama :(
You guys are dumbasses. Lower doesn't always equate to better handling. Going past 1.5" is pushing it. If it was designed to be low, then yes it's better to be low, but for regular cars (non sports cars) going too low will hurt the handling. There's nothing worse than having no suspension travel going around turns that aren't smooth as glass.
F1 cart racer
yes but there is still not enough travel. a suspension is finely tuned and evrything has to be coordinated together with out this u have an ill handeling car.
I'm a llama :(
Originally Posted by recycledpaper
^ wouldn't there still be some suspension travel even if its 0 finger gap? i have room within the wheel well..
That said, I'm gonna drop my car to tuck in the back and have 0 gap in front cause I'm tired of it looking so high! It doesn't look bad now, but it would look so much better slammed. Winter is coming and I'm hesitant, but I think I'll still do it. I just don't like the harsher ride that comes with it.
First EVER K24 Turbo CL
Originally Posted by Motohip
There may be room in the wheel well, but that doesn't mean there will be room for the struts to compress. Especially if you hit a bump. You'll be bouncing off your bump stops which has a really high spring rate and your struts aren't going to handle that well.
motohip: after dropping F/R to 0 finger gaps, i was thinking of installing F/R sways as well as taking it to a place in gardena for professional suspension tuning.
is that what you were talking about?
I'm a llama :(
Is that what you were talking about?
Just drop it, get your sway bars, get an alignment...if they can get it up on the rack! and you're set. You will need a camber kit if you don't already have one.
I think I'm keeping this CL stock for a while. I'd like to lower it, but hate the harsh ride after it. Plus lower is usually worse for about everything excepting cornering performance and looks.
I know first hand. I also have a lowered civic hatchback... Going 100mph on a 70 zone...a small dip in the road, CLUNK you hear the road hit your exhaust system. Not to mention un even thread wear and ofcourse who could forget the bumpy ride. heh
I'm a llama :(
It's weird...I lowered my car more and the ride is BETTER! Bumps don't affect the car much now and I feel more glued to the road. Feels more solid than before.
Oh and I lowered it as much as possible but it only goes to 1.5 finger gap in the back...it won't tuck . The front will tuck, but I don't wanna look stupid, so it's pretty much 1.5 fingers in back and 2 fingers in front.
Edit: It's only the right rear that won't drop that low. It's on the lowest setting, but the left rear is like halfway. The left rear will tuck, but there's no point if the right rear won't.
Miss th 3.0
the picture shows what area adjusts, therefore we can go as low as we want without sacrificing ride quality, we can also adjust the spring tention like normal coilovers to make it stiffer...etc this is why i love my d2's
~HondaF1~
Basically, lower the damn thing!
Having said that, a camber kit (as good as it is, especially for tire wear), will hinder handling a bit.
7-30-05 First Place STS!
a car's suspension is composed of more than springs and shocks...which you guys seem to be so worried about...yes they are still important, but are only two components of your suspension
upper and lower control arm positioning, tie rod positioning, and caster will all effect your toe and camber curve upon compression which determines overall grip
slamming a car = pointless and imo stupid as hell...keep the lower control arms and tie rods as horizontal as possible...the upper control arm unfortunately can't achieve this position
ya.....ok
^ i plan on getting my car's suspension tuned after dropping my car a bit.. corner balancing and stuff like that. would it help?
i gaurantee you won't be any faster even if your car was corner balanced and had a 60/40 front to rear weight ratio
^ but would it help at all? i got a buddy who drives an NSX and he has a friend named jon that always dials in his suspension... so yeah =/
johnpancakes014
09-27-2015 12:58 PM
STL TL-S
09-23-2015 08:52 PM
