Wheel Offset
Old Jul 29, 2003 | 03:41 PM
RippinRide's Avatar
Wheel Offset
I know that our bolt pattern on our cars is 4/114, correct? But the perfect offset for our wheels should be somewhere in the 42 mm area. I would really like to know what offset is and if you could get by w/ a 40 mm offset? Thanks for your time
Old Jul 29, 2003 | 04:54 PM
ju5tchi11in's Avatar
roomate has a CL too
search
Old Jul 29, 2003 | 06:10 PM
RippinRide's Avatar
I did but there was not anything specific to my ?
Old Jul 29, 2003 | 06:16 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Bolt pattern is 4 x 114.3.
Stock rims are 50mm off-set (at least on the '97 3.0CL).
I have 42mm on my 18's.
40 would work.
Old Jul 30, 2003 | 12:03 AM
RippinRide's Avatar
Thanks for the info...I havent seen any sites stating the .3 of the 114.3 on the bolt pattern is the .3 a givin or must it state so?
Old Jul 30, 2003 | 04:02 AM
ATLcl98's Avatar
Atl/Mia reppin'
i think the .3 is a given; for the most part the bolt patterns are 4 x 100 and 4 x 114.3
Old Jul 30, 2003 | 04:12 AM
joeshmoe's Avatar
My Home Planet
Mine are 40mm. It works fine.
Old Jul 30, 2003 | 04:59 AM
d5c5b's Avatar
DOOKS of hazard!!!!
how bout 45 offset?
Old Jul 30, 2003 | 08:13 AM
lowpost's Avatar
Originally posted by d5c5b
how bout 45 offset?
45 is good for 17's - my wheels are 17x7 w/ 45mm offset and they sit just like factory.
18's shouldn't be a problem either at that offset as long as you stick close to your stock diameter AND you don't go too wide
also depends on how low your car is
Old Aug 5, 2003 | 06:58 AM
Zigried's Avatar
What about 225? IS that too wide with a 45 offset?
Old Aug 5, 2003 | 09:13 AM
Zigried's Avatar
Old Aug 5, 2003 | 06:01 PM
dhauter's Avatar
I've have 19 inch hart c2's with a sportline drop and 215/35/19s and they ofset is 45. That ofset is perfect for my car with the drop, didn't have to mod the fender lip at all and it clears the front rotors by about a hair. My car is a 97 2.2
Feb 25, 2020 09:57 AM
KB1_EJ6
Aug 28, 2016 08:25 AM
BreezyTL
Jul 26, 2016 12:52 PM
nuldabz
Sep 3, 2015 05:49 PM
bailey24
Aug 31, 2015 05:38 PM
