wheel alignment
Old Jul 13, 2001 | 01:46 PM
drewha174's Avatar
CL- SMOOTH
wheel alignment
recently i hade the eibach-pro kit installed and they feel settled in. now my car pulls to the right. should i go to the dealer and have them adjust my alignment or should i go to a local service center, rstruass,pepboys,etc.
Old Jul 13, 2001 | 02:57 PM
Jawo's Avatar
drewha174,
It's a must to get your alignment once the springs have settled. I have the prokits with Tokico shocks. I wanna know what your camber results (the shop will give you a computerized result of the alignment and this will include your camber results) will be. Can you let me know what the results are when you get them?
Thanks!
Old Jul 13, 2001 | 03:07 PM
drewha174's Avatar
CL- SMOOTH
where? dealer or other?
Old Jul 13, 2001 | 03:18 PM
Jawo's Avatar
The dealer will most likely charge a lot more than shops like America's Tire Co., Sears, Midas, Goodyear, etc. It doesn't really matter where you get it. All these are computerized. I suggest you just go one of the shops I mentioned.
Old Jul 13, 2001 | 03:29 PM
drewha174's Avatar
CL- SMOOTH
thank you. will get back to you with the results.
Old Jul 13, 2001 | 03:38 PM
Jawo's Avatar
Thanks!
Old Jul 13, 2001 | 05:17 PM
Adrienne
Guest
Posts: n/a
Just make sure you go to a place that deals with lowered cars... some of the mainstream places have those things you have to drive up on too high up... and so just ask them if they deal with lowered cars. My friend has been turned away in shame from NTB and Sears... :-/
Old Jul 13, 2001 | 05:29 PM
CLpower's Avatar
teh Senior Instigator
Originally posted by AngelCL:
<STRONG>Just make sure you go to a place that deals with lowered cars... some of the mainstream places have those things you have to drive up on too high up... and so just ask them if they deal with lowered cars. My friend has been turned away in shame from NTB and Sears... :-/</STRONG>
Old Jul 13, 2001 | 06:06 PM
drewha174's Avatar
CL- SMOOTH
just wondering if you have the specs on the eibach prokit springs. i tried calling eibach, but being that i am from new york there's a time difference, and there closed..
drewha174's Avatar
CL- SMOOTH
Old Jul 13, 2001 | 06:08 PM
Jawo's Avatar
What kind of specs are you looking for?
Old Jul 13, 2001 | 06:18 PM
drewha174's Avatar
CL- SMOOTH
i went to pepboys and they need the specs from eibach. honestly i dont know what they mean.i guess the alignment numbers???? no clue? sorry, can you figure it out..
Old Jul 13, 2001 | 06:26 PM
drewha174's Avatar
CL- SMOOTH
i called eibach and they said to use factory specs. i finally got thru to someone. thanks. i'll try to post some pics later. our cars identical. if i get it done today,the alignment, i will let you know the specs.
Old Jul 13, 2001 | 07:46 PM
KikAzCL97's Avatar
Didn't you get an alignment with they put the springs in
Old Jul 16, 2001 | 12:03 PM
drewha174's Avatar
CL- SMOOTH
i could'nt get the alignment. i need a camber kit. camber results are negative. will order camber kit. once every thing is in order i will let you know results. thanks,sorry for getting back so late, had a busy weekend....
Old Jul 16, 2001 | 02:50 PM
Jawo's Avatar
What do you mean you couldn't get the alignment? You should be able to get it even if your camber is bad. And as I understand it, you'll be putting prokits so your camber shouldn't be all that bad. Are you sure you reall need one? If I remember it right, the CL manual says plus-minus 1 degree of camber is alright.
james357
Feb 13, 2016 02:37 PM
Zonian22
Nov 14, 2015 01:20 PM
GhostTL09
Sep 19, 2015 01:57 PM
Zonian22
Sep 2, 2015 08:19 AM
