What is "vortec"
If your talking about GM's Vortec Engine, thats represents GM's engine design that uses something called "vortex technology". It actually creates a vortex inside the combustion chamber. If supposed to be more efficient and create a better air-to-fuel mixture during combustion.
Taken from howstuffworks.com
"VTEC (which stands for Variable Valve Timing and Lift Electronic Control) is an electronic and mechanical system in some Honda engines that allows the engine to effectively have multiple camshafts. As the engine moves into different rpm ranges, the engine's computer can activate alternate lobes on the camshaft and change the cam's timing. In this way, the engine gets the best features of low-speed and high-speed camshafts in the same engine."
and the actual site is here.
