What the hell is wrong?
Old Oct 14, 2005 | 04:23 PM
shnee's Avatar
Land of Pleasant Living
The car was running fine last weekend.. it's just been parked until today.
I drove it like half a mile and then it started accelerating by itself, even when I began to depress the brake.
I thought that was really weird, so I parked it.
It was just sitting there revving itself.. the needle was jumping 1-2 rhythmically.. going to 2 then dropping to 1, going back up to 2, etc
Didn't sound right at all.
I went to the parking lot and didn't press the gas at all.
Just had it in drive, and it kept slowly going faster..
I was driving around in circles at like 20mph, getting faster as it went.
I never even pressed the gas!
What the hell is this about??
helllllp
Old Oct 14, 2005 | 04:35 PM
NitiNiteZ's Avatar
The Hefty 2.2
throttle cable may be stuck. This happened to me... make sure u have a ground wire attached. If not.. then the electric surge it needs to start the car will go through the throttle cable and melt the plastic around it. luckily i have a manuel and was was able to put it in neutral (while still reving) and drive it to the shop and have it check out. But this is just what happened to me.
Old Oct 14, 2005 | 07:32 PM
Lunchbox's Avatar
Scissor Me Timbers!!
Yeah that sounds like a throttle problem. If could be a malfunctioning throttle sensor or the throttle cable might be stuck like NiteNitez said.
Old Oct 14, 2005 | 09:00 PM
shnee's Avatar
many thanks, that was just enough help for me to uncover this great DIY thread
https://acurazine.com/forums/showthread.php?t=146759
seems he had the same exact problem..
thanks again
Old Oct 15, 2005 | 02:48 PM
wilp99's Avatar
idle air control valve 100% sure
Old Oct 15, 2005 | 05:55 PM
shnee's Avatar
Wilp, would that DIY fix my problem?
I hear you're the guy in the know, so what do you suggest I do about this?
Old Oct 16, 2005 | 09:25 AM
wilp99's Avatar
change the valve. i dont think the diy works all the time. atleast you wont have to worry about it again.
Old Oct 16, 2005 | 09:57 PM
shnee's Avatar
thanks wilp.. any idea how much this fix is gonna run me?
Old Oct 16, 2005 | 11:20 PM
wilp99's Avatar
bout 75$ for the valve. and its pretty easy to install..
here its #2 on this blowup.
Old Oct 17, 2005 | 06:34 AM
ayougo's Avatar
B A N N E D
i dont know
Old Oct 17, 2005 | 03:47 PM
shnee's Avatar
thanks.. ive been looking for this part but cant find it.. i might just not be looking in the right places.. you wouldnt happen to know the # would you?
Old Oct 18, 2005 | 11:00 PM
wilp99's Avatar
http://www.acuraautomotiveparts.org/...prddisplay.jsp
look under throttle body
go to a honda dealership and get one for a 98-01 accord they are the same.. so is the ones on the 01-03 cl non type s. go call junkyards, or go to honda or the nearest acura dealership.
Old Oct 18, 2005 | 11:01 PM
wilp99's Avatar
honda will try to tell you that its different but its the same p/n and everything and it even comes in a honda package from acura.. infact every part ive ever ordered has come in a honda package.
Old Oct 19, 2005 | 04:10 PM
shnee's Avatar
i need to get another part fixed/replaced too, and i was told it's a huge pain in the ass to do.. i wonder if i buy these parts and bring them to the auto shop if they'll just charge me labor and install them?
and do you think it's safe to drive my car there (a few miles) as it is?
thanks for your help wilp
Old Oct 19, 2005 | 10:45 PM
wilp99's Avatar
yea..its safe.. whats the other part? egr maybee cause thats covered under extended warranty. 80k miles
Old Oct 19, 2005 | 11:42 PM
artbran's Avatar
666 Speed
Just one last thing. I had the same problem but my check engine light came on for it. The code that it trew was P0505. I called Honda and they told me it was the idle control valve. I think that i ended up paying like $85 for it at Honda.
Old Oct 20, 2005 | 11:26 AM
shnee's Avatar
the other problem is this "squirrel cage" fan makes a lot of noise about half the time i drive. it's located above the footspace under the glove box.
this is what i was told about it.
"The fan problem you are having sounds like a failed motor bearing. You may need to replace the "squirrel cage" fan. It is a real pain in the ass though. I had to do it in my Teg, and it sucked ass. . . The squirrel cage will run you proll $300 at a dealer, but if there is a salvage near you, you can prolly get it for closer to $50 to $75"
if i kick the casing around the fan, it will stop the noise for a little, and then start back up eventually or after i hit a bump.. but sometimes this noise isnt there at all.
do you think this calls for a total replacement? right now i just ignore it and turn up my music.
if i were to call for used parts, could i get it out of an accord (year)?
ttimberlak443
21
Oct 22, 2016 10:23 PM
datadr
Mar 23, 2016 01:39 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
DerrickW
Nov 15, 2015 05:52 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
