Weird Noise
Old Jul 13, 2006 | 12:57 PM
blueCL's Avatar
Need For 6 Speed
Weird Noise
I think it's coming from the brakes or somewhere around there. It sounds like metal rubbing against metal BUT it doesn't come when i hit the brake but when i accelerate or even when i'm just rolling. Sometimes when i hit the brake it goes away and sometimes it just gets louder. Can anyone tell me what it is?
Old Jul 13, 2006 | 02:07 PM
CNDC's Avatar
it means you need new brake pads. that happened to me last week. and when i got the new pads. it goes away.
Old Jul 13, 2006 | 02:17 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Your pads are worn, or your rotors are warped, does your wheel shake when stopping?
Old Jul 13, 2006 | 02:34 PM
STL+3.0CL's Avatar
Matt
He said it doesn't happen when he brakes, and sometimes it goes away or gets worse when he brakes. sounds like a stuck caliper or something. When I was 16 and had my first car (95 civic) I ignored this sound and ended up paying $900 for a complete rebuild rotors and all. I think your calipers are stuck because the pads are gone.
Old Jul 13, 2006 | 04:30 PM
blueCL's Avatar
Need For 6 Speed
That's exactly what i was thinking but i am so broke right now what should i do ?
Old Jul 13, 2006 | 04:39 PM
STL+3.0CL's Avatar
Matt
If you dont feel comfortable looking at it yourself, your probably going to have to suck it up and take it somewhere. At least get a quote so you know what your lookin at. Eventually it will start to scar up your rotors! Sorry Dude, my buddy is in the exact same spot your in right now with his Mazda.
Old Jul 13, 2006 | 04:52 PM
blueCL's Avatar
Need For 6 Speed
yeah it sucks but you're right where do you think i should take it? firestone??
Old Jul 13, 2006 | 04:53 PM
(Mid-Atlantic)
at least get an estimate, could be somethin simple
Old Jul 13, 2006 | 05:33 PM
STL+3.0CL's Avatar
Matt
Thats up to you man. Dealer is way too expensive, Im my opinion Firestone and Dobbs and all those are too run of the mill. Yeah they will do the work for an honorable price, but I always have local shops with knowledgeable mechanics. They explain everything in detail to ya so you know what they're doing to your ride.
But nevermind me, if there is a firestone close to you take it there. Or Midas
Old Jul 13, 2006 | 07:44 PM
noo99cl30's Avatar
7th Gear
if it happens when you're not braking and gets louder or faster with speed, then it's not brakes...it's either a pulley belt or your alternator, but like the others said - get it checked out before it's too late.
Old Jul 13, 2006 | 10:12 PM
Jtbecool's Avatar
1997 CL 3.0 Premium (K)
Trust the midas touch.
Old Jul 14, 2006 | 08:50 AM
(Mid-Atlantic)
Old Jul 14, 2006 | 09:40 AM
Mach30SiR's Avatar
Bagel Bomber
pads, definately. Change them yourself for $30 The longer you wait the better your chances are of screwing up your rotors. When you hit your breaks the pads press against the rotor quieting the metal to metal noise. When you take your foot off the brake, the pad releases and can rub (very slightly) against the rotor. Its your pads - i had the same problem EXACTLY, and changing the pads fixed the problem - GL
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
