Vtec Controller
Old Jan 24, 2006 | 01:14 PM
spencer_homer's Avatar
i like acura
Vtec Controller
Does anyone have a vtec controller, how much did u pay for install, im lookin into buyin an apexi one, anyone know of any better ones??
Old Jan 24, 2006 | 01:19 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
vafcII is the one you want, but keep in mind the install is one thing, tuning is another. You don't need a vtec controller until you build up your motor, headers, exhaust, pullies, or your vtec controller wont' really do squat. After you put on those mods (if you plan to mod) THEN you want the vtec controller and tuned
Old Jan 24, 2006 | 01:20 PM
2point2CL's Avatar
yeah, no point really. save ur money, lower ur car
Old Jan 24, 2006 | 01:22 PM
i like acura
yeah
yeah well i know about that, i was just wonderin how much an install would cost
Old Jan 24, 2006 | 01:28 PM
99CL's Avatar
blah blah blah
Install would be free if you do it yourself. Its not that hard. I put mine in myself.
Old Jan 24, 2006 | 03:19 PM
732xghost's Avatar
so a V-AFCII would better suit a motor already with I/H/E???
Old Jan 24, 2006 | 04:03 PM
(Mid-Atlantic)
It's more or less pointless with a stock motor
Old Jan 24, 2006 | 04:08 PM
99CL's Avatar
blah blah blah
the more you have the better. =)
Old Jan 24, 2006 | 04:12 PM
732xghost's Avatar
i would get it but tuning would be a bitch, and would it hurt my gas mileage.
Old Jan 24, 2006 | 04:17 PM
agranado's Avatar
how handsome I am
tuning it properly would actually help your gas milage...
Old Jan 24, 2006 | 05:02 PM
Stew97CL3.0's Avatar
The key is "properly".
With any make and model - tuning is somthing done in a controled and monitored environment like on a dyno with a wideband o2 sensor. Unless you can see your air/fuel ratio and how it's efected by the changes you are making it's all just guess work and seat of the pants dynoing, and that can be dangerous in the hands of an amatuer.
Not to say you shouldn't tune your own car, but be aware that there is much more too it than pressing buttons. The VAFC II is a powerful tool in the right hands, but as mentioned it's a waste of money on a stock vehicle.
Old Jan 25, 2006 | 01:34 PM
ghost_masterCL's Avatar
not necesarrily. the stock 3.0 runs pretty rich past about 3500 rpms.... not that you would gain more than 5 or 6 hp by leaning it out though.
Old Jan 25, 2006 | 01:40 PM
SanJoseRoller's Avatar
I SMELL NAWZ
i hear with full bolt ons and a Vafc tuned you gain 10+ to the floor off a dyno VAFC II lets you run 2 fueling maps instead of just one, and the increments of Vtec engage points are smaller its something like you can moved the engage point between every 250 rpm instead of just 500 more "fine tune"
Old Jan 25, 2006 | 01:43 PM
732xghost's Avatar
if i had a h22 i would get it. otherwise IMO its a waste on our single slammer ecno motor. unless its totally worked out.
Old Jan 25, 2006 | 01:48 PM
RedDevil's Avatar
i need to pick one up. Its almost worth it, but it another bill for tunning
Old Jan 25, 2006 | 01:53 PM
you acn actually specifiy at what points in the rpm range you want to adjust the fuel. You only get 12 points though, and you can choose any rpm in 100 rpm increments.
there aren't really 2 fuel maps to choose from though. There is just one map setting that is always used, but depending on throttle/vtec engagement it uses a different set of adjustments.
so there is a low throttle and high throttle settings for when the engine is on the low cam lobes (non-vtec), and there is also a high and low throttle settings for when the engine has the vtec cams engaged.
there are really 4 sections where you need to set up the map, but it just depends on the throttle and vtec engagement that depends on which map is used.
I wish there were two fuel maps otherwise i woudl tune one for nitrous and one for NA.
Old Jan 25, 2006 | 01:56 PM
RedDevil's Avatar
two fuel maps would be awsome?
RedDevil's Avatar
two fuel maps would be awsome !!! does hondata have something like that ?
I SMELL NAWZ
thanks for clearin that up
knight rider
Mar 4, 2016 08:59 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
adreano17
Sep 29, 2015 08:48 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
Brandle34
Sep 23, 2015 07:20 PM
