Vtec
Old Jun 16, 2004 | 03:31 PM
rad_cl_racer's Avatar
Fawkin Gruvin
Vtec
ok heres a newbie ? but i am not sure ?? so what happens to our stock 3.0 motors when it hit's 3.75 RPM's that is different than before ? what does the V-tech technically do ?? open the valves more? or ? i know that some of you do this for a living and must know..
THANKS
Old Jun 16, 2004 | 03:37 PM
pebe's Avatar
All I know is that unless u have a DOHC like an H22, u dont feel shit. SOHC V-tec doesn't have the same feel. When i drive my boys Prelude, it kicks so much more. I basically opens more valves, but since we only have 1 cam, it doesn't do as much. Drive a DOHC and you'll notice.
Old Jun 16, 2004 | 03:55 PM
HyDrOpOnIkToKa's Avatar
HOOK EM HORNS
go to howthingswork.com
and search for how v-tec works
theres alot of other interesting things as well on there
Old Jun 16, 2004 | 03:57 PM
HOOK EM HORNS
http://auto.howstuffworks.com/question229.htm
Old Jun 16, 2004 | 04:06 PM
klepto's Avatar
Old Jun 16, 2004 | 04:16 PM
SooDARK's Avatar
05' 350z 6spd.
the 3.0's actually have a somewhat noticable vtec, from what i've heard. The 2.2/2.3's don't tho.
Old Jun 16, 2004 | 04:48 PM
wilp99's Avatar
yea the 3.0's pull pretty hard when in vtec. i think vtec opens the existing valvs more and keeps them open longer..in other words the cam has a vtec lobe which is almost 50% larger than the regular intake and exhaust lobes.
Old Jun 16, 2004 | 05:05 PM
klepto's Avatar
bah it wont let me edit
Old Jun 16, 2004 | 05:29 PM
dcsquirm88's Avatar
Guys v-tech is a phone brand.
VTEC is what Hondas have. Which by the way stands for Variable valve Timing and lift Electronic Control.
Pebecl97, 3.0 CL's have two cams and not one. They have one cam for each head. They have two heads, so they have two cams.
Basically in a nutshell Vtec works by using two sets of cam lobes. One set for low RPMS and one set for high RPMS. The high RPM set of lobes is much more aggressive than the other set, which in turn produces more power at high RPMS.
By the way in SOHC vtec cam the exhaust lobes are the same size for both high and low rpms, only the intake lobes change size.
Thats about as basic an explanation as possible.
Hope that clears some things up.
Old Jun 16, 2004 | 05:30 PM
CLpower's Avatar
teh Senior Instigator
the 3.0 has a special vtec unique to just J30A, you can feel it, but it's no where near the changeover on the DOHC motors
Old Jun 16, 2004 | 05:48 PM
azian21485's Avatar
7-30-05 First Place STS!
incase anyone doesn't know what lobes do is that they control how long the valves stay open and when to shut...valves open longer = more air into engine = more combustion = more power
Old Jun 16, 2004 | 06:43 PM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
all i have to say is that the thread is spelt wrong..............it should be VTEC not V-Tech
VTEC stands for Valve Transmission Efficency Control right?
thats what i have been told
all CL's are SOHC VTEC, not unless you swap the engine to get a DOHC
Old Jun 16, 2004 | 06:46 PM
ATLcl98's Avatar
Atl/Mia reppin'
lol, and this thread topic is what got dcsquirm back on the board? Weren't you going to sell the CL and keep the H22? And why do some of us old guys get all riled up when someone spells it v-tech? I know I do...its the only reason i clicked the link :sqnteek:
Old Jun 16, 2004 | 06:51 PM
BEETROOT's Avatar
Yeehaw
misspellings make me angry
Old Jun 16, 2004 | 08:08 PM
dcsquirm88's Avatar
Hey Atlcl98 its been a long time.
I stumbled back to the forum since I am trying to sell the CL onEbay .
I also sold the h22 as well. I'm almost completely out of the import scene as soon as I sell the CL. I've kept the CL around for awhile as a second car but its just not practical and too expensive. I really can't use the CL with my new job since I have to take customers out all the time.
I figured while I was around I would contribute to the forum. I guess we were all newbies at one time or another.
Old Jun 16, 2004 | 10:05 PM
Cocoa's Avatar
2600lb CL
Is your kit a wet kit? If so, I'll buy it....
Old Jun 16, 2004 | 10:25 PM
LCARUCA 97's Avatar
Trailblazer = SUCK
Old Jun 17, 2004 | 01:14 AM
liloj's Avatar
i like orange juice
Originally Posted by LCARUCA 97
Old Jun 17, 2004 | 02:43 AM
Ted's Avatar
Ted
I don't think that's correct. VTEC should stand for: Variable Valve Timing and Electronic Lift Control.
Even though that would make it more of VVTELC :P
Oh, and topic editted.
Old Jun 17, 2004 | 03:40 AM
white3.0's Avatar
VTEC = Valve Timing ELectronic Controll "says the Acura Mechanic working on my car" I'v always known how VTEC works but not exactly what it stood for.
Old Jun 17, 2004 | 05:19 AM
liloj's Avatar
i like orange juice
Ted is right, Acura mechanic is wrong.
Quote from "How Stuff Works"
VTEC (which stands for Variable Valve Timing and Lift Electronic Control)
Old Jun 17, 2004 | 08:53 AM
Fawkin Gruvin
hey thanks guys and that is awsome i knew that i could count on yall to tell me what the hell my car is doning when my RPM's hit 3.75 and the car just growels, i have an in take and i think that allows it to be a bit more audible.. but my NEXT queston is what the heck is the deal that allows you to ajust the RPM's at which the VTEC kicks in ???NOT vtech!!!!! Geeze , got you to click on the thred!!!
Old Jun 17, 2004 | 09:21 AM
pebe's Avatar
V-TEC controller. I think APEX'I makes it. I could be wrong.
Old Jun 17, 2004 | 12:21 PM
dcsquirm88's Avatar
Did you guys notice I wrote what VTEC stands for towards the very begining of the thread?
By the way thats what the acronym stands for and not what white3.0 mechanic said.
In order to control the vtec engangment and disengagement you have to get a vtec controller. Several companies make them from Apexi to Spoon.
The best one in my opnion is the Apexi VAFC. But like any vtec controler just changing the rpms that vtec engages at does you no good unless you know its making you more power. And in order to do that dyno tuning is the way to go.
Old Jun 17, 2004 | 12:24 PM
dcsquirm88's Avatar
Cocoa the kit in my car is a dry kit. But Im not parting anything out of the CL. Its being sold as is.
IBankMouse
Jun 13, 2020 12:53 PM
Dunnik
Sep 15, 2015 11:52 PM
Tsov Tom
Sep 6, 2015 07:56 AM
Desert Ridge
Sep 5, 2015 09:47 AM
LAMike240
Sep 3, 2015 04:35 PM
