vafc settings?? 3.0
vafc settings?? 3.0
so i just got a apex vafc1 and the shop whos going to hook it up wants some kind of idea of where to start with the settings.... i have cai, headers and full exhaust with 2.5 in pipe. also the lowest safe vtec engagement would b e nice!! anyone with simliliar mods and what yours is set at??
If the shop needs an idea on where to set it. THen that's not the shop you want, if they don't even know where to start. They should at least refer you to a dyno shop that will dyno/tune it for you.
i would take my car to someone who knows their japs or you might end up with one huge headache
If they're a tuning shop with a dyno, then they should know that they need to do a base run. Then look at the graph and see what needs to be adjusted. If they're asking you on where to start, you should just take it to a another shop in your area.
x infinite.
its so true. they need to do a base run to see WHERE it should be adjusted first.
Originally Posted by SupraManAG
if im not mistaked ghostmaster has the controller
after you get your cams in, after a few thousand miles you'll need to adjust them. Or else its loud.
Well, i did adjust mine but it still needed adjustment afterward. Just a heads up that u might need to do it again.
damn that's almost a month and a half after installing them to tune... I usually only drive about 300 miles per week, but ah well.
Originally Posted by 97Acura3.0CL
i have mine engaged at 3900 and disengage at 4200
pm me if you have any questions
I have the Version 1 too
and you can't set the high>low at a higer rpm than the low>high.
Biggie_B
May 27, 2025 05:51 PM
Jul 16, 2017 07:33 AM
