Uneven headlights...
7th Gear
Originally posted by acura2.2vtec
mine do this too, i think its normal but there are two bolts on each headlamp that can be adjusted. Do a search, I think this has been discussed
man, you gotta alot of miles!!!
I use a condom?
there are to little level thing on each one too. as long as the marks on them line up then your ok. I think the headlights also naturally point more to the passenger side.
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
theres a slot on top of the lights to put a phillips screw in. After that you need to align it w/ the leveler right next to it.
Powered By HONDA
check your head light bulbs..see if they are loosen..my brother's vw jetta used to have the same problem but found out that one head light bulb is looen..
DDT-TypeS
12-07-2006 02:02 PM
youngTL
08-17-2005 06:48 PM
