TV question?
TV question?
Ok, I got my tv to work. The tv works only when the battery of the car is on but, not when the car is running... When I turn on the car, my playstation doesn't let me play. Everything just blinks. But when the car is not running I can play the playstation. What is up with that? Anyone know what it can be? I am using a power inverter that plugs in the lighter... 95 volts....
Anyone install a power inverter through a lighter??? If so, is the positive the white wire in the center of the lighter??? I have a tester but, I don't want to cut the white wire to test it because it is too short.
Originally Posted by kub213
what do you mean by 95 volts, you need at least 300 watt inverter, and i would hard wire it with a fuse and a goo chassis ground.
u need alot bigger one than that to run a playstation. i used a 180watt inverter for a 9" tv and it barley was enough. just get a bigger inverter. id get a 700watt and never have to worry about it again.
[QUOTE=The tv works only when the battery of the car is on but, not when the car is running... QUOTE]
that's good.. when the car is running, DRIVE ONLY.. u can't play ps2 while driving..
it's dangerous!! j/k
i think it's because of the watt of inverter.. get more bigger one.. i also have 700ww and have no problem w/ it..
I have the 700wat inverter but, the first time I tried to tap it in the lighter, I end up cutting off the end of the piece that connects to the lighter. So the only way I can get it to work now is if I tap it into something. That's why I was wondering if that white wire is a postive?
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
