TV question?
Old Aug 15, 2004 | 06:56 PM
Dreamdtt2000's Avatar
TL 3.2
TV question?
Ok, I got my tv to work. The tv works only when the battery of the car is on but, not when the car is running... When I turn on the car, my playstation doesn't let me play. Everything just blinks. But when the car is not running I can play the playstation. What is up with that? Anyone know what it can be? I am using a power inverter that plugs in the lighter... 95 volts....
Old Aug 15, 2004 | 07:02 PM
TL 3.2
Anyone install a power inverter through a lighter??? If so, is the positive the white wire in the center of the lighter??? I have a tester but, I don't want to cut the white wire to test it because it is too short.
Old Aug 15, 2004 | 08:03 PM
kub213's Avatar
bam! mad crazy gumby gold
what do you mean by 95 volts, you need at least 300 watt inverter, and i would hard wire it with a fuse and a goo chassis ground.
Old Aug 15, 2004 | 08:23 PM
TL 3.2
I think it's 95 watt inverter. Anyway, it works. Anyone know y the playstation and tv is blinking when the car is running? When I turn on the key so the battery is only running, everything works fine. Whats the deal?
Old Aug 15, 2004 | 09:00 PM
wilp99's Avatar
u need alot bigger one than that to run a playstation. i used a 180watt inverter for a 9" tv and it barley was enough. just get a bigger inverter. id get a 700watt and never have to worry about it again.
Old Aug 15, 2004 | 09:38 PM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
what kind of screen? some of the indash has the feature to only play shit when the car is in park
nippon_wa's Avatar
nippon_wa 2.0
[QUOTE=The tv works only when the battery of the car is on but, not when the car is running... QUOTE]
that's good.. when the car is running, DRIVE ONLY.. u can't play ps2 while driving..
it's dangerous!! j/k
i think it's because of the watt of inverter.. get more bigger one.. i also have 700ww and have no problem w/ it..
Old Aug 15, 2004 | 09:54 PM
TL 3.2
Damn, yall probably right. Maybe not enough power while the car is running.
Old Aug 15, 2004 | 10:09 PM
TL 3.2
I have the 700wat inverter but, the first time I tried to tap it in the lighter, I end up cutting off the end of the piece that connects to the lighter. So the only way I can get it to work now is if I tap it into something. That's why I was wondering if that white wire is a postive?
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
