turn signal install
turn signal install
probly quite the noob question but thats what i am so dont hate. just received my clear turn signals and checkin to see what all the install entails..wiring and anything else? a step by step run through of the install would be great and could probably go in the noob forum...sorry if its already been covered but i searched pretty extensively and couldnt find the answer to my question so if its already covred just direct me to the thread or somthin..thanks guys
and also any bulb reccomendations or anything like that would be appreciated.
NAWWWWSSSSSS
1 Post
see the picture shove your screw driver in their slowly at the same angle as my finger is going in.... may help to push in the closer side of the turn signal... you will need amber bulbs to replace the clear ones fyi!!!! an amber bulb is an amber bulb.. doesnt matter
can you be more specific or can somebody else help me out here...do i push the screw driver into the hole in the side of the light housing and like pry it out or will it pop out or what..im pretty lost here cant really figure out how to get it out and i dont wanna try just ripping it out unless thats how you get it out
NAWWWWSSSSSS
1 Post
see where my finger is? use a flashlight and guide a phillips screw driver into that whole unscrew it and hit the closer side if you couldnt already tell its just held in there and a spring pops it out from the inside... this is the easiest "mod" if you cant figure this out sell your car and get a geo
CAFFEINE SLAVE
- just unscrew the one screw
- take the spring off the stock ones, put it on new ones
- replace bulbs if desired (amber/yellow/hyper-white) Bulb #168/194 (parking light), #7440 (turn sig)
no re-wiring necessary
Tristate ViP Crew
a jawful a somethin awful
Originally Posted by cl_jay
am i the only one that took of the bumper to put in the clear signals?
Originally Posted by sumdumguy
damn....how did you feel after you pulled the entire bumper off then realized how easy it was. I mean it's in the manual(if you have one)
you should be the one with teh geo NOT THE NOOB
Flap.
teh originated from online comunication such as that in online games, where people had limited time to type, so they accidentaly typed teh instead of the, now it has become cool to type teh normally
using leetspeak is a way to prove your online awesomeness and enlarge your e-pen0r.
like "kik yu0 r t3h 1337est h4x0|2 1 H4v3 3var m37 !!!one11!"
??? you are the elitest ?????? I have ever met!!!!!!!!!!!!
NAWWWWSSSSSS
1 Post
you are the hottest noob i have ever met!!!
*~ i am a girl ~*
okay i asked this once before but no one answered me... one of the bulbs in my right corner light burned out a while a go... i've taken them off before so i didn't think it would be a problem. well this one will NOT come off. i sat there with a screwdriver for like an hour once -- i keep turning it and moving it around different ways and nothing happens.
i REALLY need to get it off cuz i hate having a burned out bulb!! what can i do?!
*~ i am a girl ~*
it's probably rusted or curoded. beat on it.
Originally Posted by mesmerize
well i'm tryin not to break it... otherwise i'd just rip the damn thing off of there.
*~ i am a girl ~*
well I don't mean beat it to a pulp, use like a rubber malet or......i don't know your shoe.....just to jar the rust off and loosen it up.
i really don't think it's rusty... when i shine a flash light all over the place everything looks just fine... and nothing else in that area of my car seems to have rust.
or maybe your spring behind it is not installed. is this the stock lights?
is the screw stripped?
*~ i am a girl ~*
the hole is really deep, maybe you wouldn't see.
there is a tool you can use for stripped screws, don't know what it's called. my mechanic used it before. if not you might have to drill it out
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
