trannie coolers what, where and how?
my 3,0 just hit 59k and i noticed when its hot out side or if i drive for long periods she doesnt shift as smooth. i just wanted to what ttype of trannie cooler i should get, best place to get it and how to install it. thanks
112K and on 1st tranny!
I spent 160 including parts and labor. the tranny cooler was for a 14,000 GVWR vehicle and the cooler itself cost 85 bucks. It was mounted in front next to the radiator. YES it is overkill, but the car shifts so wonderfully i can mash the gas every time and feel safe
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
i did it myself. Look around there should be a thread, check the search engine. Also, i'm pretty sure there is a DIY thread on it over at accordv6.com
Cause stock sux.
I got a Hayden tranny cooler. Don't get one too big cause it will take too long to warm up the car. Did the job myself...
Total cost: sub $40.
http://photos.yahoo.com/bc/jlai3cl/v...c=ph%26.view=t
![](http://us.f1.yahoofs.com/users/b8f2d6bd/bc/3.0+CL/Tranny+Cooler+2.jpg?bcDuBs.ApNKJNO.K)
a hayden tranny cooler or any supplemental tranny cooler like B&M does diddly squat for your heat issue.....go ask anyone who builds up race transmissions. you definately need something with a GVWR of over 8500 minimum, although keep i mind a tranny flush every 15K miles is still the best and easiest way to go.
Tranny flushes are actually very bad for your transmission if you haven't done them regularly from the beginning. When the tranny fluid is flushed out it stirs up all the metal particles and shavings and can cause quite a bit of damage - at least according to the handful of tranny guys I talked to when mine went, who were all very adamant about it. Each one recommended simply draining it out and filling it back up and suggested that the flush I had the Acura dealer do 2 weeks before mine died could have been responsible... just what I was told.
Cause stock sux.
We dont' have race transmissions, thus we don't need a giant ass tranny cooler. We're not running turbos here...
We just need a little bit of cooling cause our engines run so hot.
If you overkill it you're running below optimal temperatures.
Cause stock sux.
Oh yea...
And yes, I did feel a difference in shifts (alot smoother), especially after racing on weekends, which is why I got one in the first place. So it DID do something...Something to the extent that I could feel my car act differently...
A-CL Post Whore w/N2O
Here's my input: http://www.acura-cl.com/forums/showt...threadid=73356
Pham Alvan
03-16-2016 09:17 AM
lanechanger
10-13-2015 10:56 AM
