TL-S remote works
how did you do that?? maybe you can give us a step by step instructions w/ pictures?
that's hot!! did you use the circuit board that came w/ the new remote or you put the old one in the new one?
Turn Signals are good!
if I remember right, he told me that the buttons lined up perfectly... the circuit board just had to be trimmed a little on the corners. Pat, lets see some pics of the board (comparison maybe?).
remote on ebay for real cheap: http://cgi.ebay.com/ebaymotors/aw-cg...tem=1845353917
Originally posted by Padger
Maybe this is a dumb question, but what's the big deal? The remote is just a little different looking, but it doesn't do anything else does it?
sorry, i had to say it. I would like it because I keep my 02 CL on one keyring and the 99 TL and 98 CL on another. Sure the 98 says acura in red and the 99 says it in black, but they are very similar and hard to tell apart (not that hard).
Stage 1 Audi S5
Ok sorry it took me so long to respond. To do this i switched out the circuit boards (thanks to sumkidwithacl and CL-Z for the idea and help). It sounded really easy and the buttons lined up so that was a big plus but the boards were different sizes and the battery connections were a bit different. First i started to trim the CL board but could only go so far before i would screw up the circuit board so i then started to trim away the insides of the TL remote. Then i realized the TL remote was slimmer so i trimmed the flat sides of the TL casing some to fit the wider board in. Than i put the rubber thing for the TL remote on the CL board but realized it was too thick so i did alittle trimming of the rubber thing. Than i stuck it all together and realized the battery didnt have a full circuit so i had to play around with those connections. To tell you the truth i dont know how i got the battery to work, trial and error but it does work, it just takes some time Any more questions feel free to ask and sorry for the delay
Hum........what next??
Originally posted by Acura3.0CLP
would u be interested in making a more detailed tutorial, possibly with diagrams?? (one that excludes your mistakes)
I can do this................I have been looking for a cheap key fob b/c the dealer wants $94 each for them.........if I win the EBAY auction......I will take detailed pics as I convert mine...............wish me luck on the bid war.
1SlowCL
sup guys...anyone here have done this switching remote stuff? Please put up a little tutorial for us...I want to do this but just need more info..aight...thanks..
1st gen CL ROCKS!!!
Well, basically, trim the circuit board as small as possible WITHOUT breaking the circuit.
Then, you'll need to trim and sand the battery side of the cover so it has enough room.
Also, the metal piece on the battery side of the cover can be removed.
I didn't take any picture before I start triming and sanding.
When I'm home from work tonight, I'll take a few pictures of the final cover... this should give you a good idea on how much work is needed.
1st gen CL ROCKS!!!
hehe.. sorry for this delay... my gf took my digi cam for a few days.
anyway... here is the pics to show how much sanding trimming you need to do to get it to work..
TL-S remote
TL-S remote
Stage 1 Audi S5
Nope it doesnt work. I tried despite the fact everyone said it wouldnt work and they were right, it didnt. The new remotes control the memory seats so it is a different setup then the first gen CLs Its really not that hard to swap out the boards but im assuming you dont have a remote to swap the board out of.
Oh the remote looks great but it doesnt wear well. The silver comes off so easily :-/
Originally posted by CL SLeePeR
Could you use the new circuit board that came with the remote? Has anyone tried programming the new circiut board to the cL. How do you program it with the old remote?
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
