Timing belt replacement
Old Feb 14, 2004 | 04:42 PM
John07's Avatar
9th Gear
Has anyone replaced their own timing belt. The manual talks about special tools needed. It talks about a holder for the auto tensioner. If anyone has any ideas about this, I would love to hear about it.
Old Feb 14, 2004 | 10:37 PM
wilp99's Avatar
no u just remove the plug and after u found 0deg tdc put a skinny philips screwdriver in there,....no wait thats the balance shaft. (still good info) any ways there is no tool required. u will just beable to use everyday shop tools. if u use pliers on anything timing use a rag inbetween. ull be alright. i did one in 4 hours. not my first timing belt but it was my first 2.x.
Old Feb 14, 2004 | 11:23 PM
Stapler's Avatar
well.. if the nut on the crank pully is hard to get off.. then you do need a special tool, but you can improvise with some pipe fittings and your friendly neiborhood welder... I think I gave the recipe on here once before... I can't recall the musurements of the fitting off the top of my head.
Old Feb 14, 2004 | 11:27 PM
Stapler's Avatar
search is my friend...
http://www.acura-cl.com/forums/showt...readid=111878&
Old Feb 15, 2004 | 06:34 PM
John07's Avatar
9th Gear
TIMING BELT REPLACEMENT
I have a question about the auto tensioner. When I remove the timing belt, I think the tensioner will adjust itself to the full max. If this is right, I need to know how to readjust it and get it back on the car.
Thanks JohnT
Old Feb 15, 2004 | 11:20 PM
drewha174's Avatar
CL- SMOOTH
Quick Question....How can you tell if your timing belt is going bad ???
Old Feb 15, 2004 | 11:46 PM
wilp99's Avatar
john u need to use a c-clamp big enough to compress the little piston back in,
drewha, when u hit 100k miles its bad. just replace it. or if it goes prematurely your engine will be toast. thats it. no warning just change it if the time is up.
merc009
Sep 14, 2015 06:43 PM
iCrap
Sep 11, 2015 06:21 PM
Phambam12
Sep 5, 2015 04:10 PM
asahrts
Sep 4, 2015 05:55 PM
