Time for timing belt change
Gimmie my points Biatch!
Damn I hate that the 2.3 timing belt/tune up is much sooner than the 3.0 ones. I already decided that I am going to be using:
OEM Timing belt
OEM Balancing belt
OEM Seals and gaskets
OEM water pump
NGK Wires
NGK Platinum Plugs
So still up for debate is
Distributor cap. From where
Accessory drive belts. OEM ones cost about $50 bucks for the pair
What you guys think?
OEM Timing belt
OEM Balancing belt
OEM water pump
NGK Wires
NGK Platinum Plugs
HOOK EM HORNS
OEM Timing belt
OEM Balancing belt
OEM water pump
NGK Wires
NGK Platinum Plugs
OEM Timing belt
OEM Balancing belt
OEM water pump
NGK Wires
NGK Platinum Plugs
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
