for those on 18s
Old Jan 10, 2004 | 04:00 PM
red99cl2.3's Avatar
who got the best deal?
for those on 18s
how bad is the ride?? i rode on this accord on 19s and it was a badd ride it was a brand new 04 accord. how does the CL ride on 18s?
Old Jan 10, 2004 | 04:09 PM
ju5tchi11in's Avatar
roomate has a CL too
what series tire?... 35 or 40.
the 225/40-18 isn't that bad but im not lowered yet. yeah it is a lot worse than the 205/55-16 but not super bumpy, just more noisy and you try to avoid those really large pot holes and you try and avoid the smaller ones because you think it might pop your tire or something.
no experience with 35 series but assuming even worse.
No regrets going 40 series though... except my steering wheel shakes on the freeway, but that could be because I didn't get alignment yet.
Old Jan 10, 2004 | 06:28 PM
dennis's Avatar
35 series tires ride harsh. I also have yokohama parada spec II's so it's even worse. They're directional tires. It's loud and stiff. Now that I have coilovers, I love the look. Very low profile. If you get 18's go with 40 series.
Old Jan 10, 2004 | 08:21 PM
ATLcl98's Avatar
Atl/Mia reppin'
i have 225/40/18s on Nitto 555s, they aren't very quiet tires either, but definitely more road noise, and you don't get as much cushion as you would on a 55/16" tire. On really smooth roads you almost don't notice the difference, but where are there really smooth roads?
Old Jan 10, 2004 | 10:07 PM
baka_t's Avatar
The movement has started
18's on 40's are a decent ride. Id pick up a set of nitto neo gen's the inside compound is harder so it will wear even if you have - camber. All in all the best tire i've ridden on smooth, quiet, and sticky. If you want to go cheap, get a set of champiro's there the best tire for the money and are sticky even in water. There real quiet also which is a +.
Old Jan 10, 2004 | 10:08 PM
acura1983's Avatar
i have 18s racingHart c5s and i got the thinnest tires i could find and on top of that i put in Ebich Pro KIt springs and the ride is decent almost stock...it really depends how low the drop and tires...when i first got the springs w/ my rims i slammed that bitch too the ground and the ride was real rough and jumpy so i raised it up 2 inches and the ride got much much better so it depends...are you plannin on droppin ur car?
Old Jan 10, 2004 | 10:23 PM
red99cl2.3's Avatar
no i;m not plannin on dropping the car, i though i wanted to but cant bear the expense
Old Jan 10, 2004 | 11:24 PM
dennis's Avatar
if you're not going to drop the car, you're better off with 17's.
18's with any size tires will look horrible.
Old Jan 10, 2004 | 11:27 PM
red99cl2.3's Avatar
why do u say they woudl look horrible?
Old Jan 10, 2004 | 11:35 PM
y u say it looks horrible? 17's are just like having 16's... except you go to a 50 series.
Old Jan 11, 2004 | 01:18 AM
dennis's Avatar
You'll have a huge gap. With 17's you can get larger tires that will fill the fenders.
Old Jan 11, 2004 | 09:11 AM
red99cl2.3's Avatar
but than the 17s would look smaller and taht infact would look horrible, i dont think your right about your assumption.
Old Jan 11, 2004 | 09:55 AM
1killercls's Avatar
GEEZER
Old Jan 11, 2004 | 10:44 AM
dustbuster4's Avatar
A-CL Post Whore w/N2O
My words, exactly!
Old Jan 11, 2004 | 03:22 PM
dennis's Avatar
Get you're 18's and we'll see. You'll be bitching about wanting to drop your car a month after you get them.
Old Jan 11, 2004 | 05:35 PM
r3mix3r's Avatar
ya i really like them jus put them on last week...
Old Jan 11, 2004 | 07:22 PM
ATLcl98's Avatar
Atl/Mia reppin'
i heard yokohama avs db 2's are the quietest tires...but i've only heard that by marketing
Old Jan 11, 2004 | 07:37 PM
okbye2's Avatar
I think with either 17's or 18's you would have to drop the car. There is just toooooo much gap between the fender and the tire. It wont look right. But if I were you I would go with 18's and then in the future when you come across more $$ invest on some springs!
Old Jan 11, 2004 | 08:11 PM
dennis's Avatar
I'd invest in springs before rims and tires.
Old Jan 11, 2004 | 08:15 PM
red99cl2.3's Avatar
i did but the install scared me a bit, they told me the bults were rusted so it would be a bitch to take out i guess i;ll buy the pro kit again.
Old Jan 11, 2004 | 08:54 PM
acura1983's Avatar
one of the main reason whyn i dropped my car is becuase of the fugly gap of 18s.....otherwise i would of kept it stock....however when i dropped the car it made it look hella clEEEEEEn..it made a HUGE difference, looks wise....
Old Jan 12, 2004 | 12:32 AM
dennis's Avatar
But even with the pro-kits and stock shocks, I still had a nasty gap.
Old Jan 12, 2004 | 12:33 AM
KitsJAG5254's Avatar
1SlowCL
ok.. I have the 3 Piece Racing Hart M5s and they all have Nitto NT555 on them (225/40/18) and the rims are 18x8. I'm not sure from you guys but my ride is good. The Nittos are soft and they have satisfied me well. Hitting bumps on the road or highway seems nothing.. well of course it depends on how big the bumps are.. but anyways i have no disappointments yet on them.. Nitto's make good tires.. just my opinion
Old Jan 12, 2004 | 05:32 PM
acura1983's Avatar
wat u riding on 18s 19s....bcause y dont you lower the hieght so that u get rid off the gap....wen i slammed my car i couldn't even fit two fingers in the rear..........s urz adjustable or wat?
Old Jan 12, 2004 | 06:12 PM
laslo's Avatar
~aka~chester~pingusa~
all this talk of lowering and rims is making me wish i had alot more $$$$$$$$$$$$$$$ than i really do
Old Jan 12, 2004 | 07:42 PM
when you slam your car you got no gap... how do you fit 2 fingers into the rear when it is slammed?
Old Jan 12, 2004 | 08:02 PM
dennis's Avatar
Listen noob. Pro-kits will definitely not slam your car. I have 18's wrapped on 215/35/18. When I put the pro-kits on, I still had a nasty gap because of the low profile tires. I decided to get Tein SS coilovers so I can adjust the height and use the 16 way adjustable dampers. My tires are almost tucking now. It looks really dope.
Old Jan 12, 2004 | 08:07 PM
dennis's Avatar
This is what my car looks like now...
Old Jan 12, 2004 | 08:14 PM
1killercls's Avatar
GEEZER
I wanna move to Hawaii
Old Jan 12, 2004 | 09:03 PM
baka_t's Avatar
Old Jan 12, 2004 | 11:59 PM
1SlowCL
sup dennis.. when did you put your rear lip and is that the 97 Accord rear lip?
Old Jan 13, 2004 | 12:15 AM
lnsyone's Avatar
CL 4 LYFE
dennis's car is hott.
Old Jan 13, 2004 | 01:54 AM
dennis's Avatar
I put the rear lip on a few months ago. It's the 94-95 rear lip.
Old Jan 13, 2004 | 09:48 PM
acura1983's Avatar
i sayd i couldnt even fit two fingers in my rear finder wen i lowered it...
Old Jan 13, 2004 | 09:51 PM
acura1983's Avatar
......sure it does.....
Old Jan 13, 2004 | 09:53 PM
dennis's Avatar
Nevermind dumbass.
Old Jan 14, 2004 | 05:08 PM
acura1983's Avatar
Old Jan 14, 2004 | 05:39 PM
lnsyone's Avatar
CL 4 LYFE
Nevermind dumbass.
ditto
TSX 09
33
Oct 25, 2015 01:32 AM
Crazy Bimmer
Feb 7, 2006 09:36 PM
cljosh
May 4, 2002 12:19 AM
cljosh
Apr 7, 2002 03:15 PM
Water-S
Sep 1, 2001 06:11 PM
