Surging idle—Need help
Old Mar 24, 2019 | 07:53 PM
Mudcat's Avatar
It all started when I got a code indicating my EGR was the problem. First I cleaned my EGR and since that did not help I replaced it. After getting the same code again I disassembled the Plenum and throttlebody and completely cleaned out the gunk in my EGR port. After reassembling, my idol started surging. It would go up and down up and down as long as my car was in neutral or park. I could drive the car but my idle was too fast in drive. I remove the throttlebody and saw that my idle air control valve was filthy. I cleaned it, reassembled it and still have a surging idle. Any recommendations would be appreciated.
Old Mar 27, 2019 | 10:01 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
You either need to clean the Throttle Position Sensor or replace it
Old Mar 29, 2019 | 11:36 AM
Acura_CL3.0's Avatar
Check for vacuum leaks. If you replaced throttle body gasket / intake manifold gasket double check for leaks. Mine did the same after messing with egr and cleaning out passages.
ghost_masterCL
1G CL Problems & Fixes
18
Dec 26, 2019 01:36 AM
Montaigne
Mar 14, 2017 10:59 PM
mikeyh_01
Mar 25, 2009 06:51 AM
mohenny
Mar 14, 2008 09:31 AM
Nicky Pass
Oct 13, 2002 04:20 PM
