Stuck Drivers Seat
Old Mar 27, 2004 | 11:06 AM
MikeSwing's Avatar
Stuck Drivers Seat
How do you fix the automatic seat? Sometimes it will move forward on its own when you lift the switch and most of the time it won't.
Old Mar 27, 2004 | 04:59 PM
red99cl2.3's Avatar
who got the best deal?
you gotta buy a new switch for it i believe.
Old Mar 27, 2004 | 05:31 PM
MikeSwing's Avatar
How much is a new switch? If its crazy expensive then I can live with it.
Old Mar 27, 2004 | 06:47 PM
wilp99's Avatar
does it move ok when u fold it forward? if not, the switch is not the problem, its prolly the motor, or the track may be too dry.
Old Mar 27, 2004 | 06:49 PM
MikeSwing's Avatar
When I fold it forward, it gets stucks a lot and sometimes it moves forward. How do I fix the dry track and with what?
Old Mar 27, 2004 | 06:57 PM
wilp99's Avatar
u can use eather lighium grease. which is usually white, or u can just use axle grease. put alittle on ur finger and put a butter lube of it on the track. ull prolly need the seat to be all the way forward and then back to do it. or even take it all the way out. it only takes like 10 min to take it out. does it sound like its hitting anything when its going forward (rubbing noise) mine used to till i greased it. let me know what happens. since it does it both with the switch and the folding, its eather a motor, or dry track.
Old Mar 27, 2004 | 07:21 PM
MikeSwing's Avatar
The motor works. It just gets stuck a lot. I'll try your idea and let you know what happens.
Old Mar 27, 2004 | 09:19 PM
dragon084's Avatar
1999 CL3.0
theres change under your seat.
the same shit happend to me
BoricuaTL
Apr 8, 2016 01:08 PM
cm561
Jan 27, 2016 10:17 PM
PortlandRL
Sep 14, 2015 12:01 PM
kareshi
Sep 3, 2015 03:38 PM
