Strut Bars?
Old Apr 19, 2001 | 11:41 PM
BLUE2.2VTEC's Avatar
Strut Bars?
Will the strut bars from a honda accord fit the same year cl?
18"Konig Divas,intake 9.5mm plug wires,ngk platinum plugs,chin spoiler,springs,custom cat back,tint,wood grain kit,and next is headers and msd.
Old Apr 20, 2001 | 01:52 AM
CLpower's Avatar
teh Senior Instigator
94-97 accord strut bars fit
Old Apr 20, 2001 | 05:02 PM
biggiev's Avatar
How hard are these to bolt on? Anyone have directions.
97 CL 2.2
Old Apr 22, 2001 | 08:41 PM
eegret's Avatar
The CL already has a strut bar. But i bet any after market bar would be stiffer and lighter.
Old Apr 22, 2001 | 09:54 PM
CLpower's Avatar
<font face="Verdana, Arial" size="2">Originally posted by eegret:
The CL already has a strut bar. But i bet any after market bar would be stiffer and lighter.</font>
the CL's bar is not a strut bar, it doesn't go on to the struts. ANd it's very light weight and weak metal. I've felt a good difference from my aftermarket bars. And they are simple to install
Old Apr 22, 2001 | 10:42 PM
biggiev's Avatar
<font face="Verdana, Arial" size="2">Originally posted by CLpower:
the CL's bar is not a strut bar, it doesn't go on to the struts. ANd it's very light weight and weak metal. I've felt a good difference from my aftermarket bars. And they are simple to install</font>
How do you do it? This is the front bar that goes over the engine right? which did you get, will DC fit?
97 CL 2.2
Old Apr 23, 2001 | 12:42 AM
CLpower's Avatar
<font face="Verdana, Arial" size="2">Originally posted by biggiev:
</font>
anything for 94-97 accords will fit. And it's a simple install. Take off the stock bar first. Then Take off the nuts on the struts and put the new bars on. The only problem is there is a little bit of a metal tab i needed to cut off but it was real soft metal. But i have a 3.0 it might be different ont he 4 bangers but the bars do still fit all CL's
"the needle got buried at 140.....1,500 RPM later...the tach got buried"
Old Apr 24, 2001 | 11:18 PM
vtec-cl's Avatar
I have the front upper/lower and rear upper lower on my CL. Used the 94-97 application. Mild modification to put on the lower rear tie bar; minor bend to bracket. It will depend on the brand but all should fit.
97 Black, 2.2CL, 5 spd, AEM Pulley/CAI, DC Header, Thermal R/D cat back, JET ECU upgrade, Magnecor Wires, upper/lower/front/rear bars, Eibach Pro-kit, KYBs, Red emblems, clears, PIAAs, front side markers, 98 grill, Momo shift, B & M shift adapter, BBS RX 17 X 7 1/2", FZ4s plus much more.
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
lanechanger
Oct 13, 2015 10:56 AM
hashbrown
Sep 29, 2015 12:13 PM
