starting problems
Old Feb 14, 2007 | 11:43 PM
DaInFaMMuS1's Avatar
starting problems
so after i went and had a lil fun tonight w/my CL, i ran into some problems. we parked our cars afterwards to take pics with the cars still on. we snap some photos, and i go back to my car and the engine is off. i try to turn it back on, but the car doesnt turn over or anything. i put the key in the ignition and turn it all the way and nothing happens! try it w/autostart, same thing, nothing happens, just silence. my dashlight light up, and i hear a click but nothing happens when i go to start it. i doublecheck to make sure my alarm system is off, cuz it wont let me start the car if its on, and still, nothing . what could it be? my ignition? starter? clutch? alarm system acting up? i did a search on this and found nothing, so im turning to u guys before i pay for a mechanic
Old Feb 14, 2007 | 11:56 PM
732xghost's Avatar
well did you get it going??
did it click many times, with interior lights flickering??
Old Feb 14, 2007 | 11:59 PM
nope. interior light didnt click at all. my car is still sitting in the parking lot, my boy drove me back
Old Feb 15, 2007 | 12:10 AM
Sleep_DEPRIVED_Sleeper's Avatar
Turtle Charged, Biotcch!!
Did you leave your headlights/ accessories/AC on when you take pix? It happened to me more than once... battery went dead...
Old Feb 15, 2007 | 12:12 AM
asianspec's Avatar
clicking means its the starter. i changed mine a couple of months ago.
732xghost's Avatar
try and pump your clutch slightly up and down.
Old Feb 15, 2007 | 12:39 AM
i dont think its the battery, everything still lights up normally, alarm is fine, everything gets power. i tried the clutch pumping thing, tried to pop the clutch to get it to start, nothing. And i dont hear any clicking. i dont hear anything at all! I know my car died @ the spot cuz it had no gas in it, so i got some and put it in and it still wouldnt start when i tried turning it over. tried turnin the key all the way, dead silence.
Old Feb 15, 2007 | 12:57 AM
was it a constant clicking? or just 1 click? does anything else happen like your lights flicker, cuz mine didnt. How much did the starter replacement cost?
Old Feb 15, 2007 | 12:59 AM
starboy2nv's Avatar
First EVER K24 Turbo CL
starter homie
Old Feb 15, 2007 | 01:18 AM
asianspec's Avatar
id did the pep boys way and put down 220 for a lifetime warranty. you can probably get the starter for 60 and get somebody to install it for cheaper.
Old Feb 15, 2007 | 01:19 AM
asianspec's Avatar
alternator went bad, possibly the fuel pump.
Old Feb 15, 2007 | 08:34 AM
so its most likely my starter, possibly my alternator? and if its my starter/alternator would i be able to order 1 from a 94-97 accord n get that to work too?
Old Feb 15, 2007 | 08:51 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
It's the starter, if you crank it 5-6 times it'll start, you are on a bad spot. I just replaced mine in august
It'll start though
Old Feb 15, 2007 | 10:01 AM
SwervinCL's Avatar
Nom Nom Nom Nom
It'll start though
Old Feb 15, 2007 | 11:02 AM
ajtcl's Avatar
Peace, Love & Acura
The fact that it died while running makes me wonder about the alternator. My CL did the fail to start, clicking thing and it was the battery. Relize that even if all of your stuff is working, the battery may still be toast. My last battery showed 12 volts, but the amps were way down, under 60. A dead cell will do it every time. If you've had starting problems in the past, you could have a loose ground. Don't jump head long into buying stuff if you don't need it. Test what you've got first and serriously start with the battery and grounding leads. Then move on to the expensive parts.
Good luck.
Old Feb 15, 2007 | 11:11 AM
ajtcl's Avatar
Peace, Love & Acura
I forgot to ask if you tried jumping it... And whether or not you used the propper jumping proceedure.
Boosting car; + and -
Dead car: + amd grounded metal bolt or frame.
If you connected B+ to D+ and B- to D-, you could have potentially damaged the charging system, ecu, emobilizer system or the ABS control unit. An impropper boost can fuck shit up.
Old Feb 15, 2007 | 11:44 AM
732xghost's Avatar
even if your starter is shot you can still pop start the car.
Old Feb 15, 2007 | 12:01 PM
(Mid-Atlantic)
Pop tarts
Old Feb 15, 2007 | 12:06 PM
732xghost's Avatar
make sure you get a core return on the starter.
Old Feb 15, 2007 | 12:42 PM
teh CL's Avatar
Pop tarts
oh yes..
Old Feb 15, 2007 | 12:58 PM
well after spending the whole morning trying to start the car, i just had AAA tow it to a shop my boy recommended. i pray its just something loose or i need a new battery or something. i really dont understand it, even the tow guy was baffled. i have full power, lights alarm all of that, i turn the key, it just clicks once and nothing. I need my car for everyday usage, this is a big hit 4 me
Old Feb 15, 2007 | 02:05 PM
ajtcl's Avatar
Peace, Love & Acura
Sure sounds like a dead cell in the battery, or a grounding issue. I wouldn't get too worked up. It sounds very fixable.
Old Feb 15, 2007 | 02:16 PM
732xghost's Avatar
when its constant clicking its not the starter
when its grinding noises and constant cranking then thats the starter.
Old Feb 15, 2007 | 02:47 PM
its official, it was my starter. shop is trying to charge me 330 for parts and labor to have it done by tomorrow. is that way too much? should i try to get a starter from autozone on my own n have them install it? oh yeah that price includes the 30 dollar diagnostics fee to see what the problem was. what do you guys think?
Old Feb 15, 2007 | 02:51 PM
732xghost's Avatar
What!?!?!?! no way dont let them do it
ill do it for you 10x cheaper.
Old Feb 15, 2007 | 03:28 PM
ajtcl's Avatar
Peace, Love & Acura
No doubt, that is RAPE...
I'm not sure about the cost of the starter...
But that is way too much for labor. And diagnostic? Fucking scam artists. Don't get robbed...
Old Feb 15, 2007 | 03:33 PM
732xghost's Avatar
the cost of the starter should be under 100 bucks with a core return.
the labor is like 2 bolts and just getting the lower coolant hose out of the way.
Old Feb 15, 2007 | 03:45 PM
CL Platano's Avatar
Tristate ViP Crew
they must of thought you were cute and wanted to rape you with that price meng...
Old Feb 15, 2007 | 04:01 PM
(Mid-Atlantic)
Mine was $200 brand new starter and labor
Old Feb 15, 2007 | 04:03 PM
UTsmokey14's Avatar
1997 2.2CL black on black
Originally Posted by starboy2nv
starter homie
+1
My starter is gone and when you try to start my car it clicks everytime you turn the key, but all the electronics still work.
Old Feb 15, 2007 | 04:22 PM
SupraManAG's Avatar
One custom CL
buy the starter and ill put it on for you for much less
Old Feb 15, 2007 | 05:10 PM
lol im in PA guys, i cant have any of u tri state guys do it for me. and theres only 1 place to get an alternator by myself here in state college, and they charge $147.77. That means 147.77 + 30 to find the problem means 152.33 for labor. geez, i sure do miss NY for the variety of places to go to get the parts =/
Old Feb 15, 2007 | 05:41 PM
SupraManAG's Avatar
One custom CL
PS sucks
sorry
Old Feb 15, 2007 | 09:19 PM
(Mid-Atlantic)
If you weren't so far, I'd totaly put it in for you man. Sorry
Old Feb 15, 2007 | 10:50 PM
5-speed's Avatar
4x4- fat chicks cant jump
Starter isnt hard to do yourself if you have tools. Im sure you can get some tools from one of your bros if you dont have any. move the coolant hose, take out two bolts, take off a power cable, unplug a cable and youre golden.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
