Starting Delay
Starting Delay
when i start my car, most of the time there is a few second delay before the car starts. the starter works fine. theres just a delay, sometimes i ease off the clutch just a tad and it starts right up.
just in case anyone was interested or is going through the same problem i am, the problem comes from the clutch pedal assembly. the problem could either be from the pedal or some kind of linkage that needs to be re-adjusted or some kind of relay or sensor of some kind not functioning, depending on what the exact problem is, it either needs to be simply repaired like re-adjusted, or replaced.
I know for a fact that on ur clutch there are two switches. there's one further up on the clutch for the starting and there's a bottom one for the cruise control (I believe) You may want to check the alignment of those. Before I installed my remote start (You have to bypass the clutch switch) I had to push my clutch all the way to the floor and give it a lil stronger push. So just check the alignment on it
rockyboy
Jan 25, 2016 06:00 PM
but i dont know shit
