SRS light help...for those who asked
OK. This is what the connector looks like on the 3.0 I cant help you if you have a 2.2/2.3
It's under the left side of the drivers column above the hood release handle......it's got two grey wires going into it.....
Disconnect it and follow the instructions below this thread, inserting the paper clip into the piece hanging down.....
Here is a modified paper clip if you need that pic too... :P
Here is the procedure
1. Turn off ignition
2. Connect the SCS service connector (or paper clip) to the 2pin wire you take out of the yellow connector box and is now hanging from a thicker harness.
3. Turn on ignition
4. SRS light comes on for 6 sec and then goes off. Before it has been off 4 sec, Remove the SCS connector.
5.SRS light turns on again. Reconnect the SCS service connector within 4 sec of light coming on
6. Light goes off, remove connector within 4 sec after light went off.
7. SRS light blinks 2 times telling you the memory is erased.
8. Turn ignition off.
Hope it works it may take some practice. Good Luck.
Like I said before I dont recommend doing this unless you KNOW it is not a serious problem. I'd hate for your airbag to malfunction on you.
3. Turn on ignition
ENGAGE MY VTEC BABY!!!!!!
nice one or you can just go to niedjb website and get the instructions too and the codes and what they mean as well. but good job on the describtion
yea... it wont come back on unless you have a big problem.. ie bad sensor.. it will come on if the sensor is set off by something like a new stereo install or aftermarket amp wiring kit or something.. but after this quick fix it will turn off... you have to make sure that it blinks twice though. or it wont work. GOOD LUCK
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
brandnewcolony
09-12-2015 10:39 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
