Which spark plugs and wires?
Not AtlCl98 or Atl-CL
Which spark plugs should I get for the 1998 2.3 Cl? Does it make a difference? Which wires are good also and are they worth replacing after 60,000 miles?
Moderator Alumnus
Re: Which spark plugs and wires?
but you'll be fine with bosch platinum +4's. not to mention that your wallet will like you more also.
Swaps? $3000 for 50HP? :(
I've got magneocr wires and bosch +4 platinums. Love 'em.
Messing around with denso's (non-iridium) now. Trying to see how big of a spark plug gap I can run with my Accel.
Scooby Guru
Cheapo copper plugs conduct better than platinum ones but don't last nearly as long. Plus they're much cheaper... I bought all 4 NGK coppers for about 12 bucks. So if you can deal with replacing your plugs every 15k mi (which is really easy on an I4), that's the way to go! If you're lazy, get platinum. If you have a lot of extra money to burn, get iridiums.
Scooby Guru
If I had a car running a lot of boost with upgraded ignition and everything else, I'd spring for the iridiums when my current plugs were worn out to get that extra 2 hp, but on a NA car with just bolt ons, the gain would probably be more like 0.02hp compared to new copper plugs.
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
