Smoked Tail Lights
Old Oct 20, 2003 | 12:29 PM
Mitchel's Avatar
broke ass fawker
Smoked Tail Lights
How do i smoke out my tail lights. A step by step process would be nice. And possible some pics of the finished product!
Old Oct 20, 2003 | 01:01 PM
melo72's Avatar
I haven't done it to my CL, nor do i think I will, but my friend and I did it to his Cirrus. They sell a spray paint that you can use for it. Just cover the area surrounding the lights with masking tape to avoid overspray or take the lights out.
Old Oct 20, 2003 | 03:21 PM
jo0p-CL's Avatar
!egamalS
dont use the spray tint, thats not a good idea. ask people on other boards, no one has really done it here..
-shawn
Old Oct 20, 2003 | 03:37 PM
xerothermic's Avatar
i did it once before...its pretty easy. I went to the local hobby shop and bought the black tint spray that they sell for the r/c cars. in the trunk if you remove the panel for the jack and pull the lining forward, youll see four brass nuts (there should be a panel on the other side as well). They secure the brake light fixture. once you remove those, unhook the power cord, and the lights come right out. hold the can of tint about 6 -10 inches away from the light and spray away. you can vary how dark they will be by the amount of spray you use...try out a coat or two and if you think its still to light put on another (since our light fixtures curve of to the side when you stand them up on the floor, i used a hair dryer at low heat from about 3-4 feet away to help dry the paint quickly before it started to drip down the sides). when your done make sure that you can see your brake lights through the paint when you brake. i put on about 3-4 coats and it looked pretty sick. i did the spoiler led's also and i put about 7 coats on that, and the leds still showed through. The only downside to using the hobbyshops tint spray is that it fades off and eventually the red will break through and as it fades it starts to look pretty shitty...then you gotta take it all off and do it again. I never had any trouble with cops pullin me over when i did it cuz they could see the red when i would purposely brake for them to see it...but just in case, you should keep a bottle of nail polish remover and a rag in your trunk so if they do give you shit you can fix it right there without getting a fix-it ticket...hope this helps
Old Oct 20, 2003 | 03:41 PM
r3mix3r's Avatar
i think its kinda ghetto...plus jus another reason for a cop to bother you.
Old Oct 20, 2003 | 08:58 PM
Mitchel's Avatar
broke ass fawker
hey thanks a lot xerothermic...this pretty much covers it all...so with nail polish remover i can take it all completely off with no trouble?
Old Oct 20, 2003 | 09:03 PM
Mitchel's Avatar
broke ass fawker
is black tint spray the best product to use?
Old Oct 21, 2003 | 07:24 AM
ApocalypseCL's Avatar
if you want to do it go to your local speed shop and get a sray is called Nightshades
Old Oct 21, 2003 | 07:28 AM
CLpower's Avatar
teh Senior Instigator
you can also use regular window tint no? I'd do that that way it can be removed.
Old Oct 21, 2003 | 07:31 AM
Slooo97CL's Avatar
how do you smoke out tail lights? blow them shotties?
Old Oct 21, 2003 | 08:09 AM
aGUYfromHARLEM's Avatar
i have a black cl and ive always wanted to smoke them out too, could you just take a can of black spray paint and LIGHTLY give it a coat inside the light? i think that would work, as long as u dont screw it up....
Old Oct 21, 2003 | 08:13 AM
melo72's Avatar
I wouldn't suggest spray paint. I don't think that you could get it light enough, plus it could run and screw up your lights.
ApocalypseCL was right on the money. The spray is called Nightshades and can be found at any local auto parts store. It's pretty inexpensive and is meant just for this.
Old Oct 21, 2003 | 08:59 AM
Its not really no trouble....it takes a bit of muscle to rub it all off... Ive only tried the tint spray, you might want to look into this Nightshades spray that others have mentioned here, it might look better and not fade in the sun like the tint spray
Old Oct 21, 2003 | 02:29 PM
d00g's Avatar
I R 1337?
no spratpaint, too ghetto, youll have dots if you just want a light coat, and if its too thick you wont see through the lights...and yea cops will def bug ya....
Old Oct 23, 2003 | 10:56 PM
wilp99's Avatar
i had an 87 honda prelude and i did my lights. it turned out pretty good. i had to do them twice. the first time i f*&^%$ them up pretty good but i just took some rubbing alcahol and rubbed it all off took about an hour. I wanted to get rid of those numbers on the lense. to get rid of them you just take some 1800 grit sand paper and rub them down flat then take some 2000 grit sand paper and wet sand the area. infact it wouldnt hurt to wet sand the whole light assy. anyways, spray one coat at a time on each piece. wait like an hour to see how dark they will be then spray enough coats to make you happy. 3 coats is pretty dark. then take some non-yellowing clear laquer, and do one even coat. to give them the shiny look and it also protects the tint. sounds like alot but its really not. good luck.
Old Oct 23, 2003 | 11:10 PM
Mitchel's Avatar
broke ass fawker
alright...thanks for the suggestions !!!
Old Oct 24, 2003 | 04:12 AM
jorgev's Avatar
lets get some pictures up... i wana see how it looks...
Old Oct 24, 2003 | 06:05 AM
jfklennon's Avatar
If you smoke you tail-lights and someone hits u from behind, with a good lawyer (the person who hit you) can get off almost scott-free. Don't do it!
Old Oct 26, 2003 | 08:48 PM
97blkura's Avatar
I used the Nightshades tint... Turned out kind of foggy until I clearcoated it. It took a few times to get it right because sometimes the clearcoat would make the tint want to run off. The good part about the nightshades is that when you shine a light on the taillights they look red and reflect just like they did before. You can take the stuff off if you rub the stuff off with gasoline, thats what I did. It came right off. It definately looks awesome on black cars.
Old Oct 27, 2003 | 09:06 AM
melo72's Avatar
Would you be able to post some pics of your rear lights?
Old Oct 27, 2003 | 07:15 PM
97blkura's Avatar
Yeah I actaully just started to retint them today... I'll post pics when I'm done and the step by step if possible. I also did my turn signals, If you want to see how they turned out ....
http://www.angelfire.com/film/cmf2/acura1.jpg
http://www.angelfire.com/film/cmf2/acura2.jpg
http://www.angelfire.com/film/cmf2/acura3.jpg
Sorry those pics aren't the best Ill post some of the Taillights sometime this week.
97blkura's Avatar
The old tint came right off with rubbing compound even thought theyve been on for over 2 months...
Old Oct 27, 2003 | 08:03 PM
Mitchel's Avatar
broke ass fawker
Where did you get the nightshades tint at...i have been having trouble finding them
Old Oct 28, 2003 | 03:01 AM
wilp99's Avatar
summitracing.com should have it. or just get a jeggs magazine. it costs like $12.00 a can
Old Oct 28, 2003 | 10:28 AM
Mitchel's Avatar
broke ass fawker
thanks, i'll check it out
BoricuaTL
Apr 8, 2016 01:08 PM
handsom-hustla
Nov 13, 2015 05:04 PM
wusty23jd
Sep 24, 2015 11:41 AM
Ny1718
Sep 11, 2015 09:21 AM
brjones9
Sep 3, 2015 07:30 PM
