shudder at 2000rpm
Old 01-23-2009, 02:59 AM
TopEyes's Avatar
shudder at 2000rpm
heres something i notice on my automatic 1st gen cl
It happens only when its around 2,000rpm
doing an easy 40mph there is a distinct, regular shudder from somewhere which disappears when I increase the revs/speed,
that the best way I can explain it.
ive googled this and peoples opinion were:
engine mounts worn out
mass air flow
torque converter
flywheel
ignition coils
i change my spark plugs and wireset just about a week ago
i dont remember if this occurred before that. right now i got a small budget since most my paycheck goes toward books and tuition so any help or suggestion would help alot.
thanks
mike
Old 01-23-2009, 03:08 AM
TopEyes's Avatar
did search here and found somewhat similar but its an old thread
https://acurazine.com/forums/showthr...light=shudders
off to bed and just a couple nights i was planning on buying hid conversion with my money now i might wait to see if this here
gonna bust my bank account.
Old 01-23-2009, 08:36 AM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,425 Likes on 3,031 Posts
I would start with spark plugs, cap and wires, if that doesn't correct it, I would assume the TPS or Mass Airflow is going bad
Old 01-23-2009, 03:43 PM
TopEyes's Avatar
im checking those now since they're visible
ima attempt to clean the massairflow.
Old 01-23-2009, 03:51 PM
Skuuuurrrrrt!
GhettoNinja06's Avatar
I don't know if it will help but before you start getting into the tricky and expensive stuff, try seafoaming. That might clean out whatever is making the car shudder.
Old 01-23-2009, 04:11 PM
TopEyes's Avatar
where is Mass air flow (MAF) sensor loated on Acura CL2.3
I can only find intake air temperature sensor. Where is MAF sensor located on Acura 2.3 CL?
tron: Im pretty sure there isn't one on our cars.
not to confuse anyone
copied and paste this from an old thread
can anyone confirm this
i have 2.2L so this should be similar to 2.3L perhaps the same
thanks.
Old 01-29-2009, 02:22 PM
972.2's Avatar
i have the exact same problem, my motor mounts are really worn out and my torque converter slips, i know all of the other factors you listed are fine. so that can at least narrow it down to that, most likely being motor mounts.
Yikes
05-03-2021 04:29 PM
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
justin7779
12-25-2015 10:33 PM
Skirmich
09-15-2015 06:41 PM
CLBean
11-12-2002 08:00 AM
Quick Reply: shudder at 2000rpm
