sealed or ported boxes
Nom Nom Nom Nom
Which do you guys prefer???? I have been at CES for the past 3 days and have been drooling over the cars that are in there. Im gonna try and take some pics of some of them tomorrow. No CL's...boo hoo.....
DOOKS of hazard!!!!
yea, huge box and theyre not as responsive....if you think about it, they echo when they bump......a sealed box is alot cleaner....so if you want clleaner bass go with sealed....if you want MORE bass go with ported
The movement has started
Well it depends on what brand of subs you plan to get. I don't know the specifics but some brands are designed to be in ported some in sealed. JBL's come to mind i think but that's all i can remember
Ahhhhhhhh
Go with the sealed, you'll have better sound quality and deeper bass in your car. The ported will be cool, only if you plan to drive around with your trunk open and head out your sunroof.
-S namyaC-
Sealed stinks IMO, they really have very shitty qualities. If you look at their freq response chart, it looks like a mountain. They are also inefficent as hell, and usually require twice the cone area and power to play at a comparable volume to a ported box. They also require gobs of nasty EQ to make up for the before mentioned shitty freq response. The only one advantage I see to a sealed box is that you can pull a larger freq range (IE play lower) than a ported box b/c the ported box is cutoff slightly below the tuning freq. Really, if you need that sort of low bass - you should have a sub and an infrasub.
The problem is noone knows how to really build/tune the proper ported box, so everyone thinks that sealed is better. Or it could be the fact that a shop wanted $800 to make the proper ported box, and the Q-logic boxc was $99. The other problem is that most people don't understand the cutoff after the tuning freq, and wonder why ~25Hz tones sound like shit on their box tuned to 40Hz. Ported boxes have a much flatter freq curve and really sound better (if done right). They can also sound much worse if done poorly.
Cause stock sux.
Oh yea...ported does take up alot of room.
Mine took up 50% of the trunk...
http://f1.pg.photos.yahoo.com/ph/jla...=Subwoofer.jpg
-S namyaC-
-S namyaC-
Originally posted by baka_t
To properly build a box, you need a program that you can enter the subs specs and will show you the optimum enclosure and freq responses and curves.
I still have never seen a sealed box that didn't need EQ. Most professional subs that are sealed (like The Bag End) require a special controller (IE heavy EQ in a box).
As far as car audio goes sealed subs can achieve a flat response with just a crossover. Sometimes it sucks to get pro audio subs to sound good. Massive amounts of eq esp in a room with alot of slap-back. Thank god for xta's.
Pass the dutchie!
the q-logic bandpass box i have was designed for my Polx GNX 12"s, the speaker driver specs exactly match that of the box, i get great sound quality and tons of bass out of a decent pair of mid wattage speakers... those englosure programs kick ass though, if you build a box exactly to the specs of the speaker they are sooo efficent. only problem with my bandpass is the cutoff but thats ok becuase the 6x9's bump hard enough when the music is real low.
Cause stock sux.
Hey, how does that setup sound? Thinking about using that sub, of course the box will be reversed tho.
I got the gain only up to 40% and its already plenty.
-S namyaC-
It bumps HARD. A ported box that size + 1000watts running ONLY to a dual voice coil 12" Alpine Type R sub = BOOM BOOM BOOM.
these are links to jl site. to me sealed sounds better, but heh to each his own. you could decide for yourself.
http://www.jlaudio.com/tutorials/magic/sealed.html
http://www.jlaudio.com/tutorials/magic/ported.html
http://www.jlaudio.com/tutorials/magic/bandpass.html
http://www.jlaudio.com/tutorials/magic/isobarik.html
Originally posted by dragon084
ported ported ported..
sealed sounds cheapo
space savers ... what the hell . is your car a closet or a luxury automobile?
I dont know how much you spent on your box but i made mine for 34 bucks IMO all boxes are cheap its the subs that are expensive. The box is only as good as its builder.
1999 CL3.0
those bottles are sick
um.,, some sealed are okay.
our stock system blows baka t
the box i have was designed for a firebird at first. the owner of the bird
thaught it was too loud for him
my box was made custom by Marty Levy at Eurosound(l.i. ny) they are known for top notch shit
InFaMouSLink
10-30-2015 09:43 AM
