rolling fenders?
rolling fenders?
Rims should be comin in fri and i heard that if u drop more than 2 inches u might have to roll ur fenders or whatever. can someone splain how to do that just in case i have to cuz i wanna put on when i get em hola at yo boy. 1997 2.2 cl
its a tool that bolts to your hub, then you just manually push this thing in an arch motion inside the wheel well and it pushes the inner metal out to allow for more room.
but unless your puttin on TWANKIES i dont think youll need to roll anything........except a big fat blunt cause youll be soo happy you got new rims!
use a metal sniper and cut the fender every inch or so - then pound up with a rubber mallet. By cutting the fender on the inside, you reduce the chance of warping the sheet metal on the outside
my bad bout not puttin up the wheel size but there 225/40/18 i didn't think i had to i did alot of measurin and what not i just happen to have read a post that said if u drop more than 2" then u'll have to roll ur fenders or whtevea so i was just checkin up on it but thanks for the input though.
225/40/18 shouldnt rubb as long as the offset is ok. I got a little more positive offset on my wheels so they lean more towards the inner fender which i can modify without taking a chance and screwing up the outter body. But with 18's i think there is minimal problems with clearance.
teh Senior Instigator
i'm tucked up front and didn't need any trimming to even the fender liner It's very close, but it only rubs when I turn HARD.
DerrickW
11-15-2015 05:52 PM
09-25-2015 06:14 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
