rewire bose
Old Aug 17, 2004 | 02:11 AM
wakeboardfusion's Avatar
Miss th 3.0
rewire bose
i just got a new deck installed and need to get the speakers wroking, on the bose amp, what wires do i run with eachother to bypass it?
Old Aug 17, 2004 | 02:17 AM
klepto's Avatar
are you trying to run your jl comps with the stock bose amp?
Old Aug 17, 2004 | 10:27 AM
liloj's Avatar
i like orange juice
you gonna have to individually run speaker wires for your deck harness...unless you are gonna run the Bose amp...then make sure the blue wire is connected...that tells the amp to turn on...
Old Aug 17, 2004 | 12:20 PM
Hobo's Avatar
Flap.
ok.. wtf see that forum that says Audio, why does no one use it?!?!
anyways just run new speaker wire from the new head unit to each speaker.
Old Aug 17, 2004 | 12:53 PM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
:imwithstupid:
Old Aug 17, 2004 | 12:54 PM
klepto's Avatar
meh, no one really visits the a/v forum...i dont that often
Old Aug 17, 2004 | 01:37 PM
joeshmoe's Avatar
My Home Planet
There's a wiring diagram in the forum someplace, just search for it. I'll see if I can find mine.
I did it and it bypasses the amp no problem.
Old Aug 17, 2004 | 04:50 PM
Miss th 3.0
whats the easiest way to run speaker wire through the door?
Old Aug 17, 2004 | 05:03 PM
klepto's Avatar
its hard as hell to get it through the grommet..i just have the wire going from behind the dash to behind the door..you can only see it when the doors open...meh
Old Aug 17, 2004 | 05:14 PM
Hobo's Avatar
Flap.
sorry but thats
pull the grommet out of the door and then lube the wire and shove it through... its a pita but making it look clean is > the ghetto way imo
Old Aug 17, 2004 | 08:36 PM
baka_t's Avatar
The movement has started
Hook up the power antenna lead on the harness adapter to the remote turn on the deck harness.
Old Aug 17, 2004 | 11:33 PM
Miss th 3.0
ok i found what wires go to what and my deck is installed and tight!! i will post a diy for the bose amp rewire soon
cycdaniel
Dec 17, 2019 10:58 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
Medinak12
Sep 23, 2015 07:11 PM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
AkuraCLS
15
Aug 29, 2001 03:41 AM
