replacing timing belt...Oem vs Generic?
Im replacing my timing belt and water pump but im trying to cut some of the cost. Do you guys recommend buying all oem parts or can i get away with putting generic parts on?...thanks in advance
teh Senior Instigator
guys, i'ma bout to order parts to do my replacement
let me make sure I have my list together
Water pump, Timing Belt, TB Tensioner, what else do I need?
and can someone give me the part#'s for these from www.acuraautomotiveparts.org
I've worked for a few dealership part departments, what I've learned is most aftermarket parts exceed the oem specs anyway (at least with smaller scale parts).... This applies to most things except brake pads... always go factory with brake pads.... But most AM stuff should come with a warranty. My opinion aftermarket belt + aftermarket water pump + factory tensioners + prestone antifreeze (orange cap-green fluid) + good mechanic = happy consumer
mada51589
05-03-2022 08:54 PM
Skirmich
09-15-2015 06:41 PM
asahrts
09-04-2015 05:55 PM
