Replacing my high beam light with yellow/amber light
I was interested in replacing my high beam light to the yellow/ amber color lights. Is that possible or has anyone else done that before? I guess what Im saying is like its sort of like a built in fog light system like the 90-93 acura integras. It doest have to be a fog light, but does anyone know if they do make a light bulb style that is yellow that will fit into the high beam section?
Something like that, but how do I have my high beams light on at the same time when I turn on my parking lights? Do I have to connect the wiring from the parking light and saughter it to the high beam light? Now I actually dont want high beams at all, I just want lights that are yellow/amber in color that are like your regular headlights fit into the high beam compartment that turns on and stays on when all lights are turn on.
^^^ i did what klepto did.
but that caused me to get pulled over wasted. luckily i was right in front of my house when he caught me, i got off the hook.
thats why im not doing a Rear Fog Light mod anytime soon.
i told the officer that my car came stock like that. he was just like, matthew go inside your house and go to sleep.
plus those yellows on the TL's and JDM fronts arent nearly as bright.
The driving light on the JDM integ fronts is aimed like a low beam, and most DRL's run the high beam bulb at half power so you aren’t blinding everyone on the road.
Originally Posted by klepto
wait, are you running a modified 194/168 bulb or are you just driving around with your high beams on with a yellow 9005 bulb. If it's the latter then I understand why you got pulled over
https://acurazine.com/forums/showthr...=184752&page=1
i think this is what the op wanted.
I know this thread is old but I am looking for an answer.
I am confused right now as there are two different packaging for the NOKYAs Yellow bulbs im looking at and cant confirm which one is Official/Better.
Its either:
http://www.jdmstyleusa.com/catalog/arctic_yellow_h7.jpg
Or
http://ecx.images-amazon.com/images/I/41YIifBQzPL.jpg
Can anyone help me out plz?
Its either:
Or
Looks like the ones i put in for my low beams. They work fine
Intensity and wattage are the same with those packages... but the bulbs are different... one has a cap one doesnt... my low beam ones are capped. So maybe the capped ones are 9006 and the uncapped ones are 9005?
mada51589
05-03-2022 08:54 PM
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
